Re: A5 alloys on a4 –
16-01-2014,10:37 AM
Originally Posted by
Sparky_143
thanks for the reply
so the different ET shouldn't be an issue even when lowered?
Be careful, the A5 and A4 have a different track. Chassis is the same but the body on the A5 is wider - hence the different ET. Those A5 alloys (if the standard "Y" design) can work with a A4 but will sit right under the bodywork (I think the A4 ET is 45mm so you are looking at a wheel that's 13mm or so further out from the centre of the car. This might cause issues with rubbing depending on how low your suspension is.
I think this is widely discussed on the US forums and the general consensus is not to do it without checking the interference carefully
Here is a picture of an A4 with stock A5 wheels - you can see how far they protrude (3rd and 4th pictures)
S4 (Collected on 21/9/09)-Deep Sea Blue, black silk nappa leather, heated S4 sports seats, Tech. Pack (with 3G MMI, AMI and cruise), Phone Prep. Low, DAB Radio, Full drive select and Sports Differential, B&O, Comfort Pack, Parking Plus, Storage Pack, Adaptive lights, High beam assist, Advanced Key, TPM.
