Thread: Audi a6 avant 2.0tdi 2007 - mmi problems
  1. Question Audi a6 avant 2.0tdi 2007 - mmi problems
    Jan 2014
    Plymouth UK
    I would be very grateful for any advice anyone can provide on a problem with the MMI on my Audi A6 Avant 2.0 TDI 2007 Model (Chassis Type 4F0) (MMI version: colour screen, Bose Surround Sound, Radio, Navigation, 6 stack CD Changer, telephone).
    The radio stations on the MMI started to drop off along with the reception. Suspecting the Aerial Amp (R24), I removed the FM coax cables from either side of the amp, connected them together and reception improved a little. So good, so far. I then went on to check the 12v power supply to the amp and carelessly allowed the contacts to short (pins 30 to 31)!!! This blew the 5Amp fuse in the right hand rear compartment (listed as MMI Aerial Amplfier) which I replaced.
    The MMI now does not come on and at best the MMI screen intermitently brights up and then goes off again. Therefore, no radio or anything - I suspect this will be an expensive mistake!!!.
    Diagnostics conducted as follows
    1. I have tried the MMI reset (pressing setup, middle knob and top right control button) to no avail.
    2. I have checked all the fuses and found no further failures.
    3. I ran my VAG COM diagnostics. Editing to the relevant, this reported:
    07-Control Head -- Status: Cannot be reached 1100
    0E-Media Player 1 -- Status: Cannot be reached 1100
    37-Navigation -- Status: Cannot be reached 1100
    47-Sound System -- Status: Cannot be reached 1100
    56-Radio -- Status: Cannot be reached 1100
    4. I interrogated the CAN gateway with the following which I assume corresponds to the self induced short:
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Control Module Part Number: 4F0 910 468 A HW: 4F0 907 468 D
    Component and/or Version: Gateway H11 0070
    Software Coding: 6CEE53C51B3104
    Work Shop Code: WSC 02334 758 00200
    VCID: 2759FFAFEF7D
    1 Fault Found:
    00384 - Optical Databus
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 230
    Mileage: 141421 km
    Time Indication: 0
    Date: 2014.01.04
    Time: 15:33:24
    5. I then ran the Optical Bus Diagnostics, results as follows:
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK OK
    07-Control Head(High/D3)OK OK
    0E-Media Player 1 OK OK
    47-Sound System ERROR ERROR
    56-Radio ERROR ERROR
    6. I have removed the amplifier J525 (4F0 035 223 G) which I assume corresponds to the sound system and the radio (4F0 035 541 L) and have them on my bench.
    I would be very grateful for any advice on what I should do next to fix this sorry state, preferably without spending too much cash!
    In advance, very many thanks.
    Ivan S
  2. Re: Audi a6 avant 2.0tdi 2007 - mmi problems
    46 Post(s)
    Welcome
    All the fibre connections plugged in?
  3. Re: Audi a6 avant 2.0tdi 2007 - mmi problems
    Jan 2014
    Plymouth UK
    Hi Chris,
    Yes, all the fibre connections are good.
    Ivan
  1. 6spd manual transmission & rear diff oil change on 2007 A6 Avant 3.0tdi quattro
    By aw911 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-04-2015, 02:24 PM
  2. MMI problems '07 A6 2.0tdi S-line.2g high
    By Taximan6660 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-11-2013, 04:18 AM
  3. 2007 Audi A6 2.0tdi
    By jim28 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-05-2012, 08:55 PM
  4. Snow chains on Audi A6 2.0TDI avant 2007
    By benzaug in forum Wheels and Tyres
    Last Post: 21-11-2010, 11:30 PM
  5. 2.0TDi Sline 2007 Sportback Common problems to look for ?
    By Sunny in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-06-2010, 09:23 AM
