Thread: 7 digit postcodes
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: 7 digit postcodes
    Apr 2009
    Surrey
    178 Post(s)
    Quote Originally Posted by Rs4cab View Post
    How can I tell which unit I have ?
    2 fairly easy routes to determining which you have are either, if the map display gives a 3D perspective then it is the HDD version also if when you sect Media and you have the option of a Hard Disk as a source then it also confirms its the HD version. No 3D and no HDD Source then its the DVD version. Also is there a Navigation DVD or SD card (the last run of the facelift switched from DVD to SD card) in the drive in the glovebox? If use then it is the DVD system
  2. Re: 7 digit postcodes
    46 Post(s)
    Quote Originally Posted by johnsimcox View Post
    Thankfully RS4 has updated his sig and is running 2G High
  3. Re: 7 digit postcodes
    Feb 2014
    Northampton
    Yeah sorry hadn't saved it when I set up thanks for the info
    2006 A6 3.0 TDi Avant Quattro Tiptronic Le Mans
    fully mapped
    Bi-Xenons, Advanced Park Assist with rear view camera, MMI 2G High Nav, Dab & 6 CD Changer, rear load blind, Bluetooth.
  1. RNS315 StNav and 7 digit postcodes
    By Passat Sport in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 24-08-2020, 11:40 AM
  2. Voice recognition & 7 digit postcodes
    By Gwynmawr in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 28-08-2013, 10:37 PM
  3. Sat nav and Postcodes
    By Kar Krazy in forum In Car Entertainment
    Last Post: 03-08-2013, 12:43 PM
  4. Satnav and postcodes
    By marakova in forum In Car Entertainment
    Last Post: 04-11-2012, 05:31 PM
  5. 7 digit postcodes on basic-spec MMI Nav
    By a8toa6convert in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-05-2012, 06:55 AM
