Thread: fuelling problems
  1. fuelling problems
    Nov 2013
    Glos
    hi all
    I usually put vpower in my 2.0fsi but yesterday put £20 of tesco 99 in. Today the engine management lights comes on and I plugged it in and got these codes
    16575/P0191/000401 - Fuel Pressure Sensor (G247): Implausible Signal
    16814/P0430/001072 - Catalyst System; Bank 2: Efficiency Below Threshold
    18068/P1660/005728 - Coolant Fan Control 1: Short to Ground
    16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
    Is it just coincidence with the tesco fuel, anyone else had problems?
    I've cleared the codes and will keep my eye on it, I don't really understand the coolant fan code but the rest seem to be fuel related?
  2. Re: fuelling problems
    46 Post(s)
  3. Re: fuelling problems
    Nov 2013
    Glos
    Thanks, I'd done a quick google and checked the ross-tech website for each code I just wondered as a collective of codes it points to something else and the tesco fuel is the only thing that's changed, do you think it's just coincidence?
  4. Re: fuelling problems
    Feb 2009
    Probably just a coincidence.
  5. Re: fuelling problems
    Nov 2013
    Glos
    Ok, rescanned and nothing yet, put some more vpower in today, feels a tiny bit lumpy like a coilpack could be on it's way out but I might be imagining it through over analysing!
  6. Re: fuelling problems
    Nov 2013
    Glos
    Ok rescanned today after an EML, Got a coilpack missfire on cylinder 2 so will change that
    but also got
    17439/P1031/004145 - Intake Manifold Tuning Valve (N316): Setpoint Not Reached
    and also the same code as before
    On the vcds wiki page it says
    Special Notes
    • When found in Audi A3 (8P), the complete Coolant Fan may need to be replaced. Detailed Instructions and Repair Information can be found under Recall 19D8 (2004439).
    but I can't find anything further on it?
    Anyone had this before?
  7. Re: fuelling problems
    Nov 2013
    Glos
    Still getting the same code
    1 Fault Found:18068 - Coolant Fan Control 1: Short to Ground P1660 - 002 - Lower Limit Exceeded - Intermittent
    Fan very noisy sometimes, seems to come on more when the aircon/heater console is on and will occasionally throw an EMLCould this have an effect on the car shaking a bit on the motorway too? Have had all the wheels balanced and the tracking isn't out
  1. Please Help Golf over fuelling
    By golpass in forum Golf MK4 - 1999 - 2004
    Last Post: 02-08-2011, 10:47 PM
  2. 1.4 16v over fuelling
    By paulgti in forum Polo - Derby - Lupo - Fox
    Last Post: 14-09-2009, 03:49 PM
  3. A6 Over Fuelling
    By soulsearcher in forum New Member Introductions
    Last Post: 28-04-2008, 09:19 PM
  4. Over Fuelling
    By Shelleyc in forum Audi A3 - Archive Topics
    Last Post: 18-01-2008, 05:27 PM
  5. over-fuelling
    By chelski205 in forum Archive posts
    Last Post: 05-10-2007, 05:29 PM
