Thread: 2.0 tdi broken crankshaft - unbelievable i know !
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
  1. 2.0 tdi broken crankshaft - unbelievable i know !
    May 2013
    crewe cheshire
    anyone suffered this (or even heard of it happening)
    what damage could i have - other than the broken crankshaft?
    need to consider selling as is maybe? = car is otherwise pristine
    57 plate SE deisel auto
    cheers
  2. Re: 2.0 tdi broken crankshaft - unbelievable i know !
    46 Post(s)
    What's your engine code?
  3. Re: 2.0 tdi broken crankshaft - unbelievable i know !
    May 2013
    crewe cheshire
    its BPK
    and sorry about the double post i got confused with the B6 sticky in the section above
  4. Re: 2.0 tdi broken crankshaft - unbelievable i know !
    Norfolk
    Quote Originally Posted by markcliff View Post
    cheers
    If the crankshaft is really broken you need to fit a good secondhand engine. That will be cheaper than a proper repair to yours. Even so you can expect a bill of £2000 or more.
  5. Re: 2.0 tdi broken crankshaft - unbelievable i know !
    Pembrokeshire
    22 Post(s)
    is this the same car thats just had a recon engine fitted to it ?
  6. Re: 2.0 tdi broken crankshaft - unbelievable i know !
    DSG4ME Guest
    DMF vibration probably caused it or simply some slag iron in the part.
  7. Re: 2.0 tdi broken crankshaft - unbelievable i know !
    May 2013
    crewe cheshire
    Yes zolaf, and it's a few months out of warranty. Not that the warranty was worth the paper it was written on of course.
    DSG4 lost drive, rolled to a stop, sounds like a bag of spanners. no prior symptoms.. First thoughts were DMF but that appears ok , garage say broken crank.
    Looking like leasing a Sportage for peace of mind, had enough of vw, financially it's been a disaster
    Question is what to do with a lovely SE in perfect nick ...... apart from the engine ?
  8. Re: 2.0 tdi broken crankshaft - unbelievable i know !
    Pembrokeshire
    22 Post(s)
    wow, that really is very bad luck. now, are we certain its a broken crank ? if so, one end of it won't be spinning and the engine would sound worse than a bag of spanners. is the engine out of the car ?
  9. Re: 2.0 tdi broken crankshaft - unbelievable i know !
    May 2013
    crewe cheshire
    Yep, I want see that for myself too. Told them to leave it till after Xmas then will pop over for a look. I want to see the break.
    Replacement crank is £250 - 300. But if the crank has broke there could be lots of other damage (unseen) done too.
    The AA said DMF when he heard it. The first mechanic said DMF when he heard it But after further inspection he could rotate the crank a few degrees freely without turning the engine. Assuming there should be zero free play it has to be a broke crank - does it Not?
  10. Re: 2.0 tdi broken crankshaft - unbelievable i know !
    Pembrokeshire
    22 Post(s)
    what was he turning a few degrees ? front pulley maybe ? could be that broken, they do fail, a lot more often than you hear of a broken crank. its not unheard of, my brother broke on in a vauxhall viva in about 1980, hit about 15,000 rpm and went bang. thats the only one i have ever seen myself and i was only 6 at the time.
  1. passat 2006 tdi crankshaft sensor
    By marc7 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-01-2017, 08:25 AM
  2. Totally unbelievable plane landing with one wing (vid link)
    By Col in forum Chat - Completely Off Topic
    Last Post: 18-07-2009, 07:22 PM
  3. Please Help Removing crankshaft pully nut and stopping crankshaft moving
    By BobProperty in forum Golf MK3 - 1993 - 1999
    Last Post: 20-05-2009, 11:20 PM
  4. unbelievable!!!!
    Last Post: 13-02-2009, 02:40 PM
  5. Tdi (AFN) crankshaft pulley removal
    By fantasiagreen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-06-2008, 12:14 AM
