Thread: 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
Results 1 to 9 of 9
  1. 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    Nov 2012
    coalville leicestershire
    MIL light stayed on when started car this morning
    Runs & idles fine
    VCDS shows as below & returns after clearing
    Advice?
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 402 L HW: 4F0 907 401 B
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H01--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 785 00200
    VCID: 264331EE9114BF2ECEF-8073
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 250
    Reset counter: 255
    Mileage: 219704 km
    Time Indication: 0
    Date: 2013.12.10
    Time: 07:43:15
    Freeze Frame:
    RPM: 1092 /min
    Torque: 85.8 Nm
    Speed: 32.5 km/h
    Voltage: 13.45 V
    Duty Cycle: 87.2 %
    Bin. Bits: 000
    Mass Air / Rev.: 282.0 mg/str
    Readiness: 1 1 0 0 0
  2. Re: 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    46 Post(s)
  3. Re: 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    Nov 2012
    Removed the air inlet pipe & moved the butterfly with my fingers.
    Does not move smoothly, jumps, jams & feels intermittent in movement.
    160mile round trip, 4 hours & £250 lighter I have a new VDO/Siemens throttle body
    Took the old one apart and confirmed its the normal failure, black plastic quadrant gear is fubar.
    1 1 0
  4. Re: 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    Nov 2012
    Somerset UK
    So is the replacement TB exactly the same or has it been improved?
    Also any idea what causes some to last for ever and others to wear out, or do they all go at around 135k miles?
  5. Re: 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    Nov 2012
    According to my research (readings Gup's post Most Lemon A6 page 9)
    4E0 145 950 has changed from rev C to rev J
    I can't find any details on what the changes were.
    I don't feel inclined to disassemble the new part.
    Mine failed at 136k, looking at the design they will all fail
    I was looking at a fix but don't currently have the time
  6. Re: 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    Mar 2008
    11 Post(s)
    Was it difficult to remove (refit)?
    I bought a replacement for mine from ECP (VDO) but been sitting on it for a few months now waiting to get it done.
  7. Re: 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    Nov 2012
    Easy, did in less than 5min at the place I got the part from.
    Hardest bit is getting at the lowest of the 3 torx screws. I used a UJ and 200mm extension
    Top tip use a magnet so you don't drop the screw
  8. Re: 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    Nov 2012
    Somerset UK
    So from what's been said anyone with a 100k+ car should order one of these in anticipation for theirs failing in the future
    2 x ECP part no's for my 07 3.0 quattro Part No.: 422440800 = £318 (£232.80 from carparts for less) or
    Part No.: 422440860 = £366 (£311.94 from car parts for less), how do I tell the difference...or is that given in Gups thread?
    Seems a silly amount of money to pay for the failure of a plastic cog!
  9. Re: 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    Mar 2016
    Dublin
    Hello,
    I have got the same error just minute before engine shutdown.
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 189654 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 16:07:42
    Freeze Frame:
    RPM: 2268 /min
    Torque: 202.8 Nm
    Speed: 32.5 km/h
    Voltage: 13.91 V
    Duty Cycle: 64.3 %
    Bin. Bits: 000
    Mass Air / Rev.: 628.6 mg/str
    Readiness: 0 0 0 0 0
    Managed to get to parking area but now can't start engine for longer than 1-2 sec. It is really frustrating, even if manage to keep the throttle for few secs it smoke a lot and engine RPMs gone crazy. Any thoughts ?
    Might it be EGR fault ? But I dont see any errors about it...
    regards
    Karol
  1. 005445 - Throttle Valve Controller - a different cause (and fix).
    By Duncan Clarke in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-01-2013, 05:05 PM
  2. Intermittent Electronic Parking Brake Malfunction
    By Dino07 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-08-2012, 09:26 PM
  3. Throttle Valve Controller
    By animal in forum Polo - Derby - Lupo - Fox
    Last Post: 22-03-2010, 10:12 PM
  4. 17608 Boost Pressure Control Valve N240 Mechanical Malfunction
    By shabazmo in forum Audi A3 - Archive Topics
    Last Post: 31-01-2009, 06:46 PM
  5. Question EGR Valve (N18) Electrical Malfunction
    By blackhove in forum Golf MK5 - 2004 - 2009
    Last Post: 21-10-2008, 12:30 AM
