Thread: ABS Fault Codes
Results 1 to 10 of 15
  1. ABS Fault Codes
    Sep 2008
    I have a couple of ABS fault codes and would like a second opinoin.
    2 Faults Found:
    00287 - ABS Wheel Speed Sensor: Rear Right (G44)
    35-10 - - - Intermittent
    00287 - Shareware Version. To Decode all DTCs
    16-10 - Please Register/Activate - Intermittent
    Are these fault codes linked to each outher?
    Do you think I need to replace the rear sensor and if so has anyone done this?
  2. Re: ABS Fault Codes
    Aug 2011
    Meath
    Do you have an ABS light showing? They may be old codes clear them and see if it returns. The sensor is cheap and easy to replace
  3. Re: ABS Fault Codes
    Sep 2008
    I have cleared the codes so will keep an eye on it.
    I think I have had this error code before!
  4. Re: ABS Fault Codes
    Sep 2008
    Ok I went for a drive 30 mins after I cleared the codes and the ABS light came back on. Now when I try to clear it it will no go.
    35-00 - -
    So I guess its the sensor that need to be switch out. Does anyone have a guid for this I have seen a video on youtube but its very crood.
  5. Re: ABS Fault Codes
    Aug 2011
    Meath
    Easy to change buy a genuine replacement takes 30 minutes if it's tight
  6. Re: ABS Fault Codes
    Sep 2008
    Looks like the part is easy to get hold off to a look
    And this is the video I found
    Part 1 + Part 2
  7. Re: ABS Fault Codes
    Aug 2011
    Meath
    Go to a dealer or TPS buy a genuine sensor
  8. Re: ABS Fault Codes
    Sep 2008
    Really! Ok I will call the dealer tomorrow or TPS
  9. Re: ABS Fault Codes
    Pembrokeshire
    22 Post(s)
    before you rip it out, do confirm it is the sensor that broke. its only a coil of wire inside a case with 2 wires sticking out, so check it has resistance and compare it with another known working sensor. if its out, replace it, if not, check the wiring. i have known so many get replaced when they worked just fine and this was only realised when a new one is fitted and the same fault occurs.
    1 1 0
  10. Re: ABS Fault Codes
    Mar 2010
    Wales
    Quote Originally Posted by MathewRB View Post
    Hi Mat, Have managed to fix it? Was it actually the sensor?
  1. Please Help A4 B6 ABS warnings flashing ABS shutdown but no codes
    By WiltshireA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-09-2012, 12:50 PM
  2. ABS Warning light, No fault codes.
    By k_h in forum Golf MK4 - 1999 - 2004
    Last Post: 04-09-2011, 04:40 PM
  3. abs trouble codes
    By bonner in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-05-2009, 04:47 PM
  4. Vag-Com works but fails to pull ABS module fault codes.
    By julex in forum VCDS - General Questions
    Last Post: 27-01-2009, 03:12 AM
  5. ABS Fault, have fault code readout....
    By nemeth782 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-08-2008, 12:15 PM
