Thread: Engine just died.
Results 21 to 30 of 36
  1. Re: Engine just died.
    #21
    Pembrokeshire
    22 Post(s)
    hmm, that shouldn't cause a fault. has it got a dpf ? if so, idling like that will block it. maybe thats a factor.
  2. Re: Engine just died.
    #22
    Sep 2013
    Weston-s-Mare, UK
    What's a DPF?
  3. Re: Engine just died.
    #23
    Nov 2009
    46 Post(s)
    diesel particulate filter, check your data sticker for 7gn, if its there then no dpf is fitted, if you cant see 7gn then you have one.
  4. Re: Engine just died.
    #24
    Sep 2013
    Weston-s-Mare, UK
    Is the data sticker the one in the spare wheel recess?
  5. Re: Engine just died.
    #25
    Pembrokeshire
    22 Post(s)
    yes, or the service book
  6. Re: Engine just died.
    #26
    Sep 2013
    Weston-s-Mare, UK
    Can't see 7GN.
    Listed under the options section are:
    BON, CN9, GOK, HJ7, JON, D3X, 1AT, 1G2, 1MH, 5RV, 5SJ, TB3, 3SO, 8TD, QG1, 8YL, 8GU, 8RM, 1LH, LO2, OYC and OG4.
  7. Re: Engine just died.
    #27
    Nov 2009
    46 Post(s)
    Anymore? None of those come back to DPF related.
    B0N = Component parts set, complying with vehicle type for Great Britain, various parts
    CN9 = Alloy wheels 7J x 16 H2 Offset 45
    G0K = 6-speed manual transmission
    HJ7 = Tires 215/55 R16 97W x1
    J0N = Battery 330 A (61 Ah)
    D3X = 4-cyl. turbo diesel eng.2.0 L/103 kW 16VTDI with pump-jet injection system base engine: T9G/TB3/TM0/TP0/TC3/TD3/TQ0
    1AT = Electronic stabilization program (ESP)
    1G2 = Steel spare wheel with original equipment tires
    1MH = Leather steering wheel
    5RV = Right exterior mirror: aspherical
    5SJ = Left exterior mirror: convex
    TB3 = 4-cylinder diesel engine 2.0 L unit 03G.B
    3S0 = Without roof rails/roof load rack
    8TD = Rear fog light for driving on the left
    QG1 = Service interval prolongation
    8YL = Radio with CD player
    8GU = Alternator 140 A
    8RM = 8 speakers (passive)
    1LH = Disc brakes, front
    L02 = Suspension range 02 installation control only, no requirement forecast
    0YC = Weight range 3 installation control only, no requirement forecast
    0G4 = Cable gearshift
  8. Re: Engine just died.
    #28
    Sep 2013
    Weston-s-Mare, UK
    Lol. No that's the lot...
    What does the DPF do again?
    Sat here in the car all the while I've been on here with the engine idling, giving it the odd burst to 3500 RPM and so far no problems....
    bit worried about taking it for a drive though in case it dies again...!
  9. Re: Engine just died.
    #29
    Norfolk
    Unlike earlier engines the versions in Passat B6 can run on the cam shaft sensor if the crankshaft sensor fails. You probably have a dodgy crank sensor or wiring , hence your fault code. Engine will be harder to start when ever it has to use the cam sensor. Crank sensor change can be a real pain so be very very careful.
    2 1 0
  10. Re: Engine just died.
    #30
    Pembrokeshire
    22 Post(s)
    dpf, diesel particulate filter. basically its a filter that traps the large black bits of soot that come out of your tailpipe. once in a while it cleans itself , usually by using extra fuel to raise the temp of the exhaust to burn off the soot and turn it to ash. once full of ash, you fit a new one.
  1. Replies: 0
    Last Post: 17-11-2013, 10:51 PM
  2. Engine died only code is 00575
    By chrisrenney in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2013, 05:22 PM
  3. My B6 engine died :(
    By JarGon in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-05-2011, 03:52 PM
  4. Tdi died and wont start,battery light came on before it died..
    By imortalmonkey in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2010, 05:44 PM
  5. Audi 80 engine died
    By bm50 in forum 80 - 90
    Last Post: 30-07-2009, 05:39 PM
