Thread: Brake disc & caliper torque settings
Results 1 to 10 of 12
  1. Question Brake disc & caliper torque settings
    Nov 2012
    North Somerset
    Folks can anyone help me with the torque settings for the front discs and calipers. Mine are standard 314mm discs and whatever caliper is fitted to that disc. I'm doing the brakes now so help needed asap
    A6 C6 Avant TDI, de-Badged, LED side lights, LED numberplate lights not just bulbs! so far!!
  2. Re: Brake disc & caliper torque settings
    Aug 2011
    Meath
    Disk 5 nm, caliper to carrier 35nm, carrier 190-nm or 196 nm on g60
    1 1 0
  3. Re: Brake disc & caliper torque settings
    Aug 2011
    Meath
    Year and engine Mr C?
  4. Re: Brake disc & caliper torque settings
    Nov 2012
    North Somerset
    Cheers Doc
    2.0TDI 2006
  5. Re: Brake disc & caliper torque settings
    Aug 2011
    Meath
    That's the correct settings mate
  6. Re: Brake disc & caliper torque settings
    If they are ATE caliper then remember that the inner pads are side.
    "The inner pad (with spring) has an arrow. The arrow must point in direction of brake disc rotation when moving forwards. May create noises if incorrectly installed."
    If they are FN3 ATE calipers then the guide pins are 25nm.
    Regards Peter
  7. Re: Brake disc & caliper torque settings
    Nov 2012
    North Somerset
    Quote Originally Posted by Peter D View Post
    Regards Peter
    I'll have a look and see if there's an arrow one side done so if there is I hope it's in the right direction is there a pic of the ATE type anywhere
  8. Re: Brake disc & caliper torque settings
    Nov 2012
    North Somerset
    Bugger there is an arrow I'll put the one not done on so arrow points in the direction of rotation and see what happens
  9. Re: Brake disc & caliper torque settings
    Only if it is the correct pad for that side. The arrow should point in the direction of rotation of the disc when moving foward. If it won't match up then you will deed to fit that pad on the other side. Regards Peter
  10. Re: Brake disc & caliper torque settings
    Nov 2012
    North Somerset
    Thanks for the help guys the pads seem to have been put in the right way
    One lesson learned is that the sensor wire breaks and when it does the wear warning kicks in. Although the pads and a fare bit of life left in them couple thousand miles maybe. I'd already bought the pads and discs so i fitted them anyway. Also the warning light was doing my head in
    Another lesson learned is the importance of using a torque wrench. I've no doubt I'd have under tightened the carrier bolts and over tightened the caliper bolts.
  1. Brake caliper torque settings
    By maxmc2 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-09-2011, 07:21 PM
  2. A6 Torque Settings for Front Brake Discs
    By bushy8 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-10-2009, 03:56 PM
