Thread: VCDS Lite and VW Golf TDI 2007.
  1. VCDS Lite and VW Golf TDI 2007.
    I've got the shareware version of VCDS as per the RossTech site and I've borrow an OBD-II lead. I have my wife's VW Golf '07 2.0Tdi with the engine management lights on and the words "emissions - garage" which comes up on the DIS when I start it.
    I've tried to use the VCDS software as per instructions, but no joy. It finds the Port 3 interface but when I save this and run an autoscan I get nothing back, it just do an awful lot of searching.
    Can someone help me out by telling me what I'm doing wrong here, or if fundamentally I'm taking the wrong approach. If someone could confirm the chassis type I should be using it might be a good start as I'm not even certain that I've got that right!!
    Thanks in advance for your help.
    Regards,
    Chris
  2. Re: VCDS Lite and VW Golf TDI 2007.
    46 Post(s)
    MK5 Golf is CAN which Lite doesn't support so this is the problem, you can however order a Micro-Can cable from Rosstech which will work fine with the MK5
    Ross-Tech: Micro-CAN Interface
    Ross-Tech Store
  1. advice on buying VCDS/VCDS-lite
    By borakev in forum VCDS - General Questions
    Last Post: 16-04-2019, 05:20 PM
  2. VCDS lite
    By smoggyrich in forum VCDS - General Questions
    Last Post: 13-08-2011, 01:05 AM
  3. Replies: 6
    Last Post: 22-03-2011, 03:10 AM
  4. vcds lite help?
    By tdigolf in forum VCDS - General Questions
    Last Post: 09-02-2011, 10:09 PM
  5. vcds lite
    By markgrff17 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-01-2011, 10:52 AM
