Thread: VW Golf TDI issue - not the starter motor... will it be the fly wheel?
  1. VW Golf TDI issue - not the starter motor... will it be the fly wheel?
    Oct 2013
    Bristol
    First post so apologies if in correct forum.. but
    I own a VW Golf TDI mk5 and for about a month it was struggling to start. Then it stopped completley and since has not started at all - there is a clicking sound but nothing else. The AA came out and said it was the starter motor, checked the battery and although low said that was the likely cause.
    Got someone out to fix it - they fixed a new starter motor, but nothing happened. They tested old and new, and both worked. The guy (after taking the money off me) said it was likely to be the fly wheel but couldnt view it without taking the clutch and fly wheel out.
    Is it likely to be the fly wheel - is it possible that the mechanic who came out to fix it was trying a fast one?
    Any help appreciated!
  2. Re: VW Golf TDI issue - not the starter motor... will it be the fly wheel?
    Pembrokeshire
    22 Post(s)
    welcome to the forum.
    with the starter motor removed you can see and feel the ring gear where it will engage. no need to remove anything else. you may need a torch and a mirror to see well enough.
    1 2 0
  3. Re: VW Golf TDI issue - not the starter motor... will it be the fly wheel?
    Colchester,Essex
    like zolaf said mirror and tourch,he should`ve done the inspection prior to fitting a new one.The starter motor is not engaging because the bendex is not travelling far enough to bridge the starter rotor.I had a case where I fitted 2nd starter motor because the 1st one was causing intermittent failure to start.Inspect the flywheel 1st before you do anything else.By the way if its a Universal starter motor I`ve had a few faulty ones and used AC delco with 24months warranty and better quality.
  4. Re: VW Golf TDI issue - not the starter motor... will it be the fly wheel?
    Up North
    A test of a starter motor off the car won't tell you much - they will happily spin away when thy don't have enough power to stir a cup of coffee.
    If the battery is low this also isn't going to help a fat lot. Try with some hefty jump leads and an additional battery for support. It has to be low for a reason. You also need to check leads and connections and a good clean up with emery does no harm.
    When you come to inspect the flywheel you can pick up a boroscope camera for not many beer vouchers from places like CPC or else can hire them. It's better than using mirrors. You can also take the flywheel out of the equation by manually turning the engine by 1/4 turn. The ring gear tends to get chewed up most at two positions 180 degrees apart where the engine naturally stops most often.
    Personally, I'd be amazed if it's the flywheel. Your symptoms of struggling for a month then failure point to something simpler. If by "struggling" you mean it sounded slow and laboured then it's very likely starter, battery, the copper between them or some combination of all three.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  1. Question possible issue with Starter motor....?
    By kenyan_alex in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 13-10-2010, 08:40 AM
  2. Dual MAss Fly Wheel or Solid Mass Fly Wheel
    By Y90USF in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-02-2010, 08:32 PM
  3. Question Starter Motor Golf 1.6
    By Loughers in forum Golf MK4 - 1999 - 2004
    Last Post: 19-01-2009, 10:44 PM
  4. Golf MK4 starter Motor Number
    By Ewster in forum Golf MK4 - 1999 - 2004
    Last Post: 21-01-2008, 09:28 PM
  5. Starter motor for Mk3 Golf TDi
    By j_coupland in forum Golf MK3 - 1993 - 1999
    Last Post: 16-04-2005, 08:13 PM
