Thread: most common oil leaks
  1. most common oil leaks
    Mar 2011
    newtownards
    Where are the most common places for oil to leak on a 1.9tdi afn engine
  2. Re: most common oil leaks
    Pembrokeshire
    22 Post(s)
    difficult one to answer really. the cam cover can leak. i presume you have an oil leak that you need to trace ?
  3. Re: most common oil leaks
    Mar 2011
    newtownards
    Yes a hard one to trace. Had it over a pit with lights etc. Seems to come from rear of engine and run down near oil filter (screw on type).
  4. Re: most common oil leaks
    Pembrokeshire
    22 Post(s)
    thats possibly the o ring on the oil cooler, if its the same as my 1z. febi do the part for it and it costs about £3.00. basically you have the oil filter housing that bolts to the block, then the cooler under it, then the filter. remove the filter and undo the nut on the central bolt to drop the cooler. there is an o ring on top of it. i also remove the housing and replace the gasket.
    looks like this VW BEETLE/BORA/CORRDOBA/GOLF/JETTA OIL COOLER O-RING/SEAL/GASKET - 038117070A | eBay
  5. Re: most common oil leaks
    Aug 2011
    Meath
    The end of the crank case breather pipe becomes brittle and breaks off. It's near the oil filter costs about €40.00 from a dealer
    http://www.ebay.co.uk/itm/Oil-Breath...item1c2f65af9d
  6. Re: most common oil leaks
    Mar 2011
    newtownards
    Thanks gents helpful as always will check these. Always good to know roughly were to look
    0 2 0
  7. Re: most common oil leaks
    Aug 2011
    Meath
    Oily devils these engines
    Quote Originally Posted by greenkeeper View Post
  1. Oil leaks
    By Adman in forum Golf MK4 - 1999 - 2004
    Last Post: 05-07-2011, 07:50 PM
  2. Sump Bolts and oil leaks......
    By bigchris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-08-2009, 01:02 PM
  3. Any Common Water Leaks
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-04-2009, 10:28 PM
  4. Few newbie Q's - Cambelt, oil leaks etc
    By Last Triumph in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-12-2008, 03:43 PM
