Thread: Passat B6 Key Fob Battery
  1. Passat B6 Key Fob Battery
    Sep 2007
    I have a Passat B6 with keyless entry. One of the key fobs now needs its battery replacing. Any clues on where to prise this apart - I've pushed as hard as I dare without getting proper information for fear of breaking it!
    Thanks,
    Andy
  2. Re: Passat B6 Key Fob Battery
    Feb 2007
    Huddersfield
    You need to remove the key for the airbag switch and glovebox first before you can take it apart.
    If you look on the silver part of the key, on one of the thinner edges you will see a small button. Push that while pulling on your keyring and the key will come out.
    The silver top then slides to one side and you can take off. The key should now come apart.
    Iain
    Car - 2006 VW Passat 2.0TDi SE Estate.
  3. Re: Passat B6 Key Fob Battery
    Sep 2007
    Thank you - that worked just fine. New CR2032 fitted.
    Andy
  1. Passat Battery replacement
    By passat owner in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-09-2007, 10:47 AM
  2. Passat Battery
    By pjkane in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-07-2007, 03:51 PM
  3. 1.8 T battery
    By johnready in forum Passat - Archive Topics
    Last Post: 07-11-2006, 02:08 PM
  4. Passat Battery drain
    By Blobnose in forum Passat - Archive Topics
    Last Post: 20-09-2006, 05:44 PM
  5. Flat Battery on VW Passat 4-Motion
    By raelill in forum Passat - Archive Topics
    Last Post: 25-10-2004, 12:23 PM
