Thread: Car won't start. No compression on motor.
Results 1 to 10 of 18
  1. Car won't start. No compression on motor.
    May 2008
    Hi there.
    Wondered if any of you had some suggestions regarding my problem. The thing is as follows:
    Had my 1.8 tfsi since new, five years and one month to be exact, and one month over warranty as we have five years here in Norway. 59000km on the counter and served at intervals. The car have been working flawlessly all the time, with just minor bugs taken care of under warranty.
    The other week i came driving home, parked the car, went in for a shower (30min) and then off to work. The car would NOT start. Cranking over just fine, a little to fine it seems. Searched my self for the obvious. Couldn't hear the puel pump prime, so wen't for it. Got it working again, but could only measure 6V in the power supply for the pump? Well, it primes and spins, but no start. Charged the battery on the car. Get 12.3 when fully charged, so maybe time to change. Try to jump start with no success.
    Ended up towing the car to a local Volkswagen mechanic as there is 100km to the nearest Audi dealer. After 10 minutes he could tell me the problem. That flop flop sound from the exhaust should ring a bell, but it didn't. Well it seems there is no compression on the motor... The VW mechanic told me it would be better to move the car to the Audi dealer for further repair.
    Have VCDS and could fetch som fault codes dating to the time the car died on me. Mostly electrical due to low voltage on the battery i think.
    Afraid this could empty my savings account. Any ideas for a simple solution to all this?
    Thanks for any reply.
    The log:
    Tuesday,22,October,2013,12:57:46:64789
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: WAUZZZ8KX9A065921 License Plate: DL96196
    Mileage: 59640km-37058mi Repair Order:
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72
    VIN: WAUZZZ8KX9A065921 Mileage: 59640km/37058miles
    01-Engine -- Status: Sporadic communication error 1000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Xenon Range -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    Address 01: Engine (------CDHB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K1 907 115 M HW: 8K1 907 115
    Component: 1.8l R4/4V TF H07 0002
    Revision: A5H07---
    Coding: 0104000C18070020
    Shop #: WSC 00590 218 88632
    ASAM Dataset: EV_ECM18TFS8K1907115M A01002
    ROD: EV_ECM18TFS_AU48.rod
    VCID: 387427B583AE9EDE6C3-806D
    No fault code found.
    Readiness: 1110 0101
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
    Component: ESP8 front H04 0060
    Revision: -------- Serial number: --------------
    Coding: 030500
    Shop #: WSC 06325 000 00000
    VCID: 78F4E7B5CB2E5EDEAC3-802D
    3 Faults Found:
    01314 - Engine Control Module
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:24:58
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x00A2
    Hex Value: 0x000C
    Hex Value: 0xB98F
    Hex Value: 0x00FF
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:24:58
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x22A2
    Hex Value: 0x0013
    Hex Value: 0x028F
    Hex Value: 0x00FF
    01200 - ABS Valves Supply Voltage
    000 - - - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 22:23:19
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x02A0
    Hex Value: 0x0034
    Hex Value: 0x8193
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 A HW: 8K0 907 064 A
    Component: BCM2 1.1 H70 0134
    Revision: 00002001
    Coding: 030100
    VCID: 2E5801ED79EA506E36F-807B
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H37 0060
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: ELVAUDIB8 H35 0039
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:24:59
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
    Component: KLIMA 1 ZONE H06 0140
    Revision: A1000000 Serial number: 0103.07.081452
    Coding: 64000000
    VCID: 70E4DF95A35E069E643-8025
    1 Fault Found:
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:24:58
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
    Component: BCM1 1.0 H22 0253
    Revision: 05022001 Serial number: 00000000170481
    Coding: 2600D0914034AF000001000300001D0D0F1C03080001010100 0000
    VCID: 30641F9563DE469E243-8065
    Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 270608 H06 0060
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
    Component: E1 - LDS H07 0070
    6 Faults Found:
    01516 - Terminal 30; Left
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 22:22:00
    00927 - Terminal 30 (Right)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 22:21:00
    00926 - Terminal 30
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 22:22:00
    03123 - Terminal 30 - 2
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 22:22:00
    03124 - Terminal 30 - 3
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 22:22:00
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:24:00
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 930 A HW: 8K0 920 930 A
    Component: KOMBIINSTR. H16 0221
    Revision: 00200000 Serial number: 991583378
    Coding: 0F04080002000008010000
    VCID: 2B5E08F94AF82546111-807E
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:24:59
    00771 - Fuel Level Sensor (G)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.21
    Time: 21:17:01
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0091
    Revision: GB102039 Serial number: 3900G086298031
    Coding: 000303
    VCID: 4688594DF15AF82EEEF-8013
    Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H04 0150
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:24:59
    03041 - Energy Management Active
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 7
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 22:18:00
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 B HW: 8K0 959 793
    Component: TSG FA H10 0170
    Revision: Serial number: 0000007286154
    Coding: 011C02204000410001
    VCID: 3F864CA9AE80A9E6AD9-806A
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 22:23:14
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0112323174
    Coding: 0100062000390040013001
    3 Faults Found:
    02615 - Fuel Tank Cap; Lock
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 24
    Reset counter: 21
    Mileage: 33473 km
    Time Indication: 0
    Date: 2011.06.20
    Time: 14:47:38
    02616 - Fuel Tank Cap; Unlock
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 38
    Reset counter: 138
    Mileage: 33875 km
    Time Indication: 0
    Date: 2011.06.28
    Time: 14:51:48
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:24:59
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
    Component: EPB Audi B8 H05 0060
    Revision: 00000003 Serial number: 00000000164070
    Shop #: WSC 00000 000 00000
    VCID: 31621A9168D44F962BD-8064
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:24:58
    Freeze Frame:
    Voltage: 11.60 V
    Count: 64
    Speed: 0.0 km/h
    Hex Value: 0x0263
    Hex Value: 0x0001
    Hex Value: 0x1010
    Address 55: Xenon Range Labels: 8K0-907-357.clb
    Part No: 8K0 907 357 B
    Component: Dynamische LWR H01 0030
    Revision: 00000001 Serial number:
    Coding: 0000004
    Shop #: WSC 06324 000 00000
    VCID: 346C138557C67ABE40B-8061
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:24:58
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T1 035 186 C HW: 8T1 035 186 C
    Component: Concert3 H02 0210
    Revision: 00000004 Serial number: AUZ5Z6H1087077
    Coding: 05020080010105000159070000
    VCID: 3776248986B091A6659-8062
    Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
    Component: Display
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 08:25:03
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 HW: 8K0 959 795
    Component: TSG HL H06 0170
    Revision: Serial number: 0000007386186
    Coding: 010C02204000210001
    VCID: FF068CA96E00E9E66D9-80AA
    3 Faults Found:
    02115 - Locking Unit for Central Locking
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 20
    Reset counter: 99
    Mileage: 59356 km
    Time Indication: 0
    Date: 2013.10.11
    Time: 14:32:48
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 99
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 22:23:14
    02111 - Motor for Window Regulator
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 59645 km
    Time Indication: 0
    Date: 2013.10.17
    Time: 22:23:17
  2. Re: Car won't start. No compression on motor.
    Aug 2011
    Meath
    If you have no compression on any cylinders then the timing belt has broken/slipped
  3. Re: Car won't start. No compression on motor.
    May 2008
    The timing belt is there. Not checked the alignment. The mechanic was talking about a valve sensor or valves stuck in open. Is that possible?
    If it IS a a faulte timing belt that have caused valvedamage, should i expect Audi to contribute to the repair in spite of not in warranty as the car has only driven 37k miles?
  4. Re: Car won't start. No compression on motor.
    Pembrokeshire
    22 Post(s)
    at what age do vw recommend changing the belt ?
  5. Re: Car won't start. No compression on motor.
    Aug 2011
    Meath
    What is the engine code? That year has a timing chain....Open to correction tho
  6. Re: Car won't start. No compression on motor.
    May 2008
    Audi says at least 100k km, and no 5 year time limit.
  7. Re: Car won't start. No compression on motor.
    Aug 2011
    Meath
    2008 Audi A4 TFSI has a CHAIN
    Quote Originally Posted by vinsj View Post
  8. Re: Car won't start. No compression on motor.
    May 2008
    Well, my bad then. I believed the one camshaft was belt driven, and the cams was chain connected. Does this rule out the bad CHAIN bit then? What could cause the valves to not open/close at the right time then?
  9. Re: Car won't start. No compression on motor.
    Aug 2011
    Meath
    The old 1.8T had a belt and a small chain on the cams. You need to post the engine code, it's on a sticker in the wheelwell and maybe on the engine
  10. Re: Car won't start. No compression on motor.
    Revision: A5H07---
    The engine code is right there - CDHB - from his VCDS Autoscan.
    MY2009 A4 Saloon 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Convenience Key, Sunroof, Adaptive Lights, Anti-dazzle Folding Mirrors, Rear Sun Blind, Heated Full Leather with Memory, Storage/Light Packs, Audi Hold Assist, Adaptive Cruise Control, Parking System Advanced, Privacy Glass, Rear Airbags, TPMS. MMI 2G with B&O Sound System, DAB Radio, DVB TV, AMI and Bluetooth Phone prep High with Privacy Handset.
  1. Important car won't start
    By nathancrowster in forum Golf MK4 - 1999 - 2004
    Last Post: 14-08-2009, 06:55 AM
  2. Engine won't start, possible starter motor problem
    By viio in forum Polo - Derby - Lupo - Fox
    Last Post: 21-12-2008, 09:30 PM
  3. Question Noise from starter motor when i start the car
    By jellis1uk in forum New Member Introductions
    Last Post: 14-10-2008, 01:35 PM
  4. Car Won't Start
    By TIBO in forum TT - 8N Forum - 1998 - 2006
    Last Post: 22-11-2007, 01:46 PM
  5. Replies: 0
    Last Post: 30-10-2007, 10:05 PM
