Thread: Rear Washer Hose Repair
  1. Rear Washer Hose Repair
    Apr 2009
    Surrey
    178 Post(s)
    The younger members of the household drive an '07 9N Polo. The rear washer hose has broken inside the rubber boot that is supposed protect it and the wiring as the tailgate shuts. Is there a simple (cheap!) solution to fixing it or do I need to get a male and female connector from the dealer. Do not really want to have to go through all of the pain of running a completely new piece of hose from the 3/4 panel to the wiper motor.
  2. Re: Rear Washer Hose Repair
    Dec 2016
    hampshire
    Same here... Any solutions...
  3. Re: Rear Washer Hose Repair
    Apr 2009
    Surrey
    178 Post(s)
    Quote Originally Posted by stuathayling View Post
    Ended up buying a male to male house connector from Halfords Halfords Hose Connector Straight 6m... (I think I used the 6mm ones not 8mm) and then using some heat shrink plastic sleeving from Maplin to hold it all in place. 3 years later still OK
  4. Re: Rear Washer Hose Repair
    Jul 2007
    glasgow
    35 Post(s)
    i put a very small cable tie on mine & it held
  5. Re: Rear Washer Hose Repair
    129 Post(s)
    1972 Post(s)
    A piece of 5-mm ID silicon hose and RTV in the ridges of the plastic pipe, leave to set-job done.
  6. Re: Rear Washer Hose Repair
    Dec 2016
    hampshire
    Thank you all for making another unexpected little job much easier ! All sorted from halfords no less !!!
  1. Air con hose repair
    By JohnPierpoint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2013, 10:09 AM
  2. Rear washer hose leaking
    By dilly2008 in forum Chat - Anything with wheels
    Last Post: 06-06-2012, 10:52 AM
  3. Avant Rear washer hose route?
    By stickleback in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2011, 07:55 PM
  4. A6 Avant rear washer hose
    By kerrywalpole in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-04-2011, 04:02 PM
  5. Rear washer repair...
    By Solari in forum Golf MK4 - 1999 - 2004
    Last Post: 27-04-2008, 10:47 AM
