Thread: Fault code p1070
Results 1 to 10 of 20
  1. Fault code p1070
    Oct 2013
    dublin ireland
    Audi a 1.6fsi 2004. Fault code p1070. Any ideas what sensor I need to change? Thanks
  2. new to audi cars
    Oct 2013
    dublin ireland
    Hello to all. New to site due to searching for help. First time.audi owner! Have the emissions light on the dash and fault code reading saying p1070. Heat sensor issue i believe. Anyone know what part needs replacing or had this code pop up. Possible prob? Thanks in advance
  3. Re: new to audi cars
    46 Post(s)
    Welcome to VWAF.
    Which model do you have?
  4. Re: new to audi cars
    Aug 2011
    Meath
    Which car, year, engine code? What did you scan with?
  5. Re: new to audi cars
    Oct 2013
    dublin ireland
    Audi a3 1.6fsi 2004 sportback . unsure of diagnostic tool make. Friend did it in a garage. Thanks
  6. Re: new to audi cars
    Aug 2011
    Meath
    You really need a scan with VCDS ,as far as I can see you need a nox sensor. You'll have small change out of €600.00 if that's what it is as it's a dealer only part
  7. Re: new to audi cars
    Oct 2013
    dublin ireland
    Thanks for that. Nox o3c sensor and control unit perhaps but if not would it be anything else?
  8. Re: new to audi cars
    Aug 2011
    Meath
    Look here for someone close to you with VCDS, VWAF User Location Map - VCDS - Google Maps A6_Chris will send them a PM for you you really need the scan done generic scanners tend to miss stuff and/or misread VAG cars.
  9. Re: emssions workshop dash message
    Quote Originally Posted by dneilom View Post
    unplug the maf and drive it, if its better replace the maf .
  10. Re: new to audi cars
    Oct 2013
    dublin ireland
    thanks for that. im meeting a guy today with vcds to diagnose and will keep ye posted. cheers
  1. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  2. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  3. VAGCOM Fault Code 00588 - Airbag fault
    By headache56 in forum VCDS - General Questions
    Last Post: 31-01-2009, 01:05 PM
  4. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
