Thread: drivers wing mirror not heating up
Results 1 to 10 of 14
  1. drivers wing mirror not heating up
    May 2007
    SOUTH LONDON
    woke up this morning and driving to garage I noticed that the drivers door mirror is steamed up and hasn't demisted, everything else works folding in, turning the mirror from the button etc. The other side is ok everything works fine there.
    Would it be seperate fuses? or one fuse for mirrors or could it be the element the heats it up.
    Anyone can shed light on this would be greatly appreciated?
  2. Re: drivers wing mirror not heating up
    46 Post(s)
    Probably a failed heating element, a vcds scan would show what's wrong.
    You can get new glass on eBay easily enough, just make sure it's heated and if you have dimming then dimming too.
    1 1 0
  3. Re: drivers wing mirror not heating up
    Oct 2005
    If you regularly leave the mirror adjuster in the central (ie on) position, the elements will eventually burn out.
    1 1 0
  4. Re: drivers wing mirror not heating up
    Aug 2013
    Craigavon, County Armagh
    I had the same issue but it was finger trouble on my part: both mirrors didn't clear. I discovered that the switch was not correctly positioned and when this was adjusted it worked fine. Your issue is odd though because one mirror clears.
    On a related point, I thought my rear screen was very slow to clear and am not perfectly sure it is heating correctly.
    Sent from my iPad using Tapatalk - now Free
    Joebland
    A6 2.7 TDI S-line Le Mans Edition 2007 (Nov)
    1 1 0
  5. Re: drivers wing mirror not heating up
    May 2007
    SOUTH LONDON
    yeah its dimming too, thanks Chris, I didn't know you can burn it out if its left on, wouldn't it turn itself off after a set time like the back window one? (relay)
  6. Re: drivers wing mirror not heating up
    Oct 2005
    Quote Originally Posted by A6-MO View Post
    Some come on with the ignition and are only active when the external temperature is below a certain figure (5*C?), some can be switched on and off - I think it's based on age (of the car, not you!)
    On the B5/6 A4 and B5 Passat they would burn out if the mirror adjuster was left in the on position - one would assume the 'better' A6 wouldn't suffer from this issue, so perhaps you're right and it's just failed of its own accord.
    1 1 0
  7. Re: drivers wing mirror not heating up
    Apr 2013
    Kent
    I had one go on my A4 B8.
    Heated and Anti-dazzle.
    £257 from Audi... ouch.
    Luckily it was changed under warranty.
  8. Re: drivers wing mirror not heating up
    Dec 2010
    Wiltshire
    I try to keep mine off the middle position. Like guys above said, mirrors elements burn out.
    Heatte antidazzle one best to buy from ebay...
    1 1 0
  9. Re: drivers wing mirror not heating up
    Mar 2009
    Essex
    Isn't the middle position on?
  10. Re: drivers wing mirror not heating up
    Dec 2010
    Wiltshire
    I n middle position heating stays on...
    Sent from my GT-I9505 using Tapatalk
  1. Replacing drivers side wing mirror? Any pointers??
    By mr c in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-02-2010, 09:30 PM
  2. Drivers wing mirror loose...
    By webchem in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-06-2008, 10:52 PM
  3. Drivers side wing mirror
    By Gozza657 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 06:55 AM
  4. Drivers Wing Mirror
    By badass76 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 01:14 PM
  5. Passat Drivers Side Wing Mirror Complete
    By tdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2008, 09:43 AM
