Thread: Glove box Multimedia unit removal
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Glove box Multimedia unit removal
    Dec 2010
    Wiltshire
    I have got Audi Multimedia unit in the glovebox. Can someone point towards correct removal keys please?
    Is it safe to disconnect it (I don't want it to go into Component protection mode).
    And the last question is where to get metal clips to hold fuse cover in place?
    I hate going to local Audi, they are bunch or morons...
    thank you.
  2. Re: Glove box Multimedia unit removal
    46 Post(s)
    keys - PC5-132 Audi Chorus Concert Stereo Radio Removal Extraction Release Keys x 4 | eBay
    safe to disconnect as its mated to your car. what are you adding?
    you can get new spring clips from audi or ebay, check they haven't fell as you were taking the panel off.
  3. Re: Glove box Multimedia unit removal
    Dec 2010
    Wiltshire
    I am going to connect microphone as i have bluetooth activated and working, but no microphone.
    I was also looking to install Sat nav but 4E0 035 652 is very rare unit.
    Thank you Chris.
  4. Re: Glove box Multimedia unit removal
    46 Post(s)
    Ah yes I remember your thread now!
    i just remembered, by the way, pay extra for your removal keys, those ones i posted above are crap and i bought these on recommendation and haven't let me down 20PC CAR RADIO STEREO REMOVAL KEYS TOOL SET CAR RADIO REMOVAL KEY KIT SET | eBay
  5. Re: Glove box Multimedia unit removal
    Feb 2009
    West Yorkshire
    10 Post(s)
    I got a few errors in ecu due to disconnecting the fibre optic, but it doesnt bring any lights, on just logs them. Some will clear on there own after a number of error free ecu checks or you can clear using VCDS
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  6. Re: Glove box Multimedia unit removal
    46 Post(s)
    They wont happen unless you turn the ignition on, keep ignition off and you'll be fault free
    Crazy - you'll find it far easier dropping the glovebox as you're gonna have to run the mic wire down anyway, 5 8mm bolts and disconnect the door motor, light and footwell light (if fitted) from one plug and of course the bits out of the mm unit.
  7. Re: Glove box Multimedia unit removal
    Sep 2013
    Measham, UK
    When I put my AMI in, I had to take the glove box out. But I tried taking the Multimedia unit out first with the keys and the wiring behind it is very tight. There is very little extra cable so it might just be easier to remove the 5 bolts to lower the glove box down.
    Audi A6 2.0 TDi S-Line Special Edition (60 Reg) Phantom Black
  8. Re: Glove box Multimedia unit removal
    Dec 2010
    Wiltshire
    Well I'm going to replace the battery at the same time so power will be disconnected.
    Any idea on glove box removal ?
  9. Re: Glove box Multimedia unit removal
    46 Post(s)
    Just posted 2 pics above
  10. Re: Glove box Multimedia unit removal
    Dec 2010
    Wiltshire
    Ok, last question:
    Does Audi use generic plug at the beck of mmi unit for the microphone or it needs to be Audi special ???
    Thanks very much for your help guys.
  1. glove box removal
    By checkmate in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-06-2013, 12:46 PM
  2. Glove Box Removal
    By Colion Preece in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-04-2011, 10:22 PM
  3. How To Glove Box Removal
    By Matt2010 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-08-2010, 10:44 PM
  4. Golf Plus glove box removal
    By Big John in forum Golf Plus
    Last Post: 17-08-2008, 05:52 PM
  5. Glove Box Removal B6
    By Davidj241 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-06-2007, 12:54 AM
