Thread: Oil & coolant capacity - 3.0 TDI (ASB)
  1. Oil & coolant capacity - 3.0 TDI (ASB)
    Oct 2006
    Engine code ASB on my 3.0 TDI.
    Wondering what the correct amount of oil for an oil change would be? Opie Oils website quotes for 6 litres in the service kit bit I'm not actually sure that will be enough!
    I would also like to change the coolant, as I don't think this has been done before, and I've had to top it up a couple of times this year with tap water so it might be a little diluted. How much G13 should I get?
  2. Re: Oil & coolant capacity - 3.0 TDI (ASB)
    46 Post(s)
    Oil is 8.2L and coolant is 12L. <<- From my reg, 2008 ASB.
    Punch your reg into this - Quantum
    Edit - elsa confirms this. I assume the 12L if you're doing a whole drain etc.
  3. Re: Oil & coolant capacity - 3.0 TDI (ASB)
    Oct 2006
    I get the same results. That's a hell of a lot of coolant! I wonder if Audi sell it in bigger quantities than the little 1 litre bottles?
  4. Re: Oil & coolant capacity - 3.0 TDI (ASB)
    46 Post(s)
    No harm in asking I suppose, Audi done a full coolant drain and refill on my A6 at its last service, old coolant was very brown, now nice and pink
  1. 2.0 tdi 140 oil capacity?
    By Andrew Turner in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-02-2019, 11:53 PM
  2. 2008 A5 3.0 TDI Quattor - Total Antifreeze / Coolant Capacity
    By gtx2010 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 04-09-2013, 10:21 AM
  3. 3.0 TDi ASB 80k+ Reliability?
    By Guest 2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-12-2012, 12:20 AM
  4. audi a4 2.7 tdi engine oil capacity
    By big jase in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-07-2011, 05:45 PM
  5. 1.9 tdi oil capacity
    By Worf in forum 80 - 90
    Last Post: 29-07-2009, 11:34 PM
