Thread: fix a stuck seatbelt?
Results 1 to 10 of 10
  1. fix a stuck seatbelt?
    Mar 2013
    Grantham
    Hi, my rear middle seatbelt has got itself stuck all the way in. No amount of tugging will release it and you can barely get your hand behind the belt to do this anyway. I think it happened when I had the rear seats down for some time and then when I put them back up the belt wouldn't pull out. It's gradually worked its way tighter back inwards. Spoke to a grage the other day, they said they would probably have to replace the whole belt (this was without even looking at the problem btw) and that'll cost me over £100!!
    Any help much appreciated as I don't really want to be paying out £100's for it
  2. Re: fix a stuck seatbelt?
    Unfortunately, this happens frequently to our A3 and the only way out is to put the seat down, get in the boot area with a socket and undo the bottom seat belt holding bolt that can just be seen under the boot carpet flap. ( keep an eye on the fixing and where the washer goes) Put the seat up and and pull out the belt until loose then redo the bolt.
    I keep the middle belt connected at all times as the problem is that when you put the seat down it takes up the slack in the belt then stretches it taught when you put the seat up and it will then not release. Its not too difficult just a bit fiddly in the boot
    I keep looking to see if there is anything that can connect onto the belt to act as a brake to prevent it taking up the slack but not found anything as yet.
    Hope you manage and save a garage visit.
    Rob
    2015 Floret silver A3 Sportback 1.4 TFSI Sport 150 COD
    2005 Liquid Blue A3 Sportback 2 litre FSI SE
  3. Re: fix a stuck seatbelt?
    Mar 2013
    Grantham
    That's brilliant!! Thanks so much Rob will give it a go this weekend and will post back if it's worked.
  4. Re: fix a stuck seatbelt?
    Mar 2013
    Grantham
    Oh, do I undo the bolt completely and remove it or just loosen it enough?
  5. Re: fix a stuck seatbelt?
    Afraid you have to undo and remove it so that you can lift it up to release the tension on the belt.
    Rob
  6. Re: fix a stuck seatbelt?
    Mar 2013
    Grantham
    Ok, thanks. Just wanted to be sure
  7. Re: fix a stuck seatbelt?
    Mar 2013
    Grantham
    Perfect Rob!! Removed the bolt and it freed up the belt straight away so happy! Thanks so much!!
  8. Re: fix a stuck seatbelt?
    Pleasure, glad to help, don't forget to connect the belt when you put the seat down which will give you the play needed when you put it back up.
    Rob
  9. Re: fix a stuck seatbelt?
    Sep 2016
    San diego
    Hi Rob,
    I have a 2007 VW EOS and the two searbelts in the backseat wjll not click. Any advice on how to fix?
    Thanks,
    Marissa
  10. Re: fix a stuck seatbelt?
    Feb 2017
    Maidenhead
    Hi Rob,
    I see you were able to help out with a jammed seatbelt on the rear of an A3. I have the same problem with an A4 Avant (59 plate). I just tried to follow your instructions, but no bolt is visible from the boot, just a plastic strip on the side, which I have opened, but there is nothing obvious to see. I would be most grateful if you can offer a solution, as the garage I went to today, suggested buying a new seat belt as the option - waiting to get the price tomorrow, which no doubt will be large! I hope to hear from you soon, Graham
  1. AUDI A4 Aircon/climate control stuck flap fix
    By stu1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-01-2013, 08:26 PM
  2. How to get Seatbelt chime and Fasten Seatbelt MSG
    By klitoni in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-08-2012, 04:52 PM
  3. seatbelt warning chime sounding with seatbelt fastened
    By tonyandkaty in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-06-2012, 11:41 PM
  4. Please Help a4 avant rear seatbelt stuck
    By bigdavehep in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2009, 10:23 AM
  5. So my rear middle seatbelt was stuck, fixedit, now how do i prevent?
    By thricefanatic19 in forum Chat - Anything with wheels
    Last Post: 18-06-2008, 01:42 AM
