Thread: Heated seats - retrofit?
Results 1 to 9 of 9
  1. Heated seats - retrofit?
    Apr 2010
    Ashford, Middlesex
    One of the very few things missing from my A4 is heated front seats, and I got to wondering if it would be possible to retrofit them? Or would it be such a costly/nightmarish job that it wouldn't be worthwhile?
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  2. Re: Heated seats - retrofit?
    46 Post(s)
    Aftermarket or OEM? The latter being the more expensive.
  3. Re: Heated seats - retrofit?
    Apr 2010
    Ashford, Middlesex
    If I do it, I think that OEM would be preferable - but then, if the difference in cost isn't all that much.....
  4. Re: Heated seats - retrofit?
    46 Post(s)
    I think the biggie in terms of £ in the oem setup is the replacement climate control panel
    BigCol done a aftermarket r/fit into a C5 A6 - A6 C5 Avant heated seat retro fit (front and rear)
    You could place the little switch down by the lumbar support switch if you want it out of the way.
    1 1 0
  5. Re: Heated seats - retrofit?
    Aug 2006
    Going by the fact that the local dealers use an aftermarket company to retro fit heated seats on both new and used vehicles, it is probably an indication that going down the OEM route is probably too expensive. The wife had them fit heating elements to her A1 and the two setting rocker switch has been fitted on the seat base.
    1 1 0
  6. Re: Heated seats - retrofit?
    Apr 2010
    Ashford, Middlesex
    Hmmm - OEM may well be out then. I don't have any lumbar support switches (nor handle, in fact - these really are poverty spec seats!) I am wondering if it might be more painless to get these fitted professionally; takes half the fun out of it, but then gives me someone to go back and nag if it goes wrong.
    Then again, do I really need them at all? Ho hum..... decisions, decisions....
  7. Re: Heated seats - retrofit?
    46 Post(s)
    They're lovely in winter, one thing I miss in my A3 as the A6 has them.
    They look pretty easy(!) on Col's guide but suppose if you fancy a challenge you could save a few £ fitting them yourself. If I were more competent at wiring I would have a bash and would fit rears too if I were good enough!
  8. Re: Heated seats - retrofit?
    Apr 2010
    Ashford, Middlesex
    Funny enough, its not the wiring that worries me, its the getting the seats out, covers off, and everything back in without damage or stray airbag lights.
    By Christmas, I hope to have paid the bulk of my credit card off, so might allow myself a wee treat and get VCDS to take care of fault codes, so might be as well leaving it until after then.
  9. Re: Heated seats - retrofit?
    46 Post(s)
    Looking at Col's thread it doesn't seem too bad but I too would worry about getting everything back together correctly.
    Seats out without warning is just to disconnect the battery and don't reconnect it again until the airbag plug is in no errors that way then
  1. Heated Seats Retrofit
    By hencyber12 in forum Golf MK7 - 2013 - 2019
    Last Post: 10-09-2013, 08:48 PM
  2. Retrofit heated seats 8P A3
    By KevinGroome in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-01-2011, 02:29 PM
  3. Heated seats retrofit?
    By M3 Compact in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-10-2009, 11:07 PM
  4. Please Help Passat heated seats (retrofit)
    By mrc77 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-10-2009, 02:56 PM
  5. retrofit heated seats to 2003 A4 Cabriolet
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-03-2009, 10:17 PM
