Thread: A4 B8 Alloys - Offset
  1. A4 B8 Alloys - Offset
    Aug 2012
    Belfast
    All,
    Real quick one. I have an A4 B8 S-Line - 2010 - factory standard. Currently has a set of 19" alloys, offset 43. Been offered a set of 18" alloys from a 2012 A4 which have an offset of 47.
    I assume these are OK to fit?
    Anything else I need to consider?
    Ronan
  2. Re: A4 B8 Alloys - Offset
    Oct 2010
    Cirencester, Gloucs
    Hi mate
    yes it's fine the offset is basically how much difference from a flat face ( I.e more offset deeper alloy if that makes sense).
    Audi A4 B8 S Line - VCDS - needle sweep - LED number plate lights - painted calipers with S Line decals - Audi Drive Select - Cruise Control - OEM S4 pedals & RS5 footrest - facelift flat bottom steering wheel - LED interior lighting pack - rear view camera/xcarlink - carbon fibre wrap interior trim - OEM S4 power fold wing mirrors - OEM rear sunblinds - OEM LED tail lights- RS4 style grill
  3. Re: A4 B8 Alloys - Offset
    Aug 2012
    Belfast
    Quote Originally Posted by hsmithboy30 View Post
    Hi mate
    Thanks for the prompt response Smithy, really appreciate it.
  4. Re: A4 B8 Alloys - Offset
    Apr 2007
    Surrey
    What are you planning to do with the 19"s?
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension (Optional), Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), spacers (10mm f, 15mm r), needle sweep, dipping mirror on reverse and badge delete. To come: LED rear lights, lows and rear window tint.
  5. Re: A4 B8 Alloys - Offset
    Aug 2012
    Belfast
    Quote Originally Posted by Phil K View Post
    Hi phil,
    Good question. The 18's are for winter tyres, will keep the 19's for better weather.
    Ronan
  6. Re: A4 B8 Alloys - Offset
    Dec 2011
    Bristol, UK
    I'd like to get some 17/18" alloys to replace my 19" on my 2011 A4 much like you've obtained. Is there anything I should look out for when finding replacements?
  7. Re: A4 B8 Alloys - Offset
    Aug 2012
    Belfast
    Quote Originally Posted by jraward View Post
    J,
    yes, initially it was going to get 17" but needed to consider the size of my brake discs and the brake cover. I felt 17s" would run too close to these parts so decided on 18s.
    other than that offset and ensuring the wheels have the correct stud numbers and are spaced correctly (check the PCD number for the set you are considering) for your model then you should be good to go. Also consider if you want genuine wheels or aftermarket copies.
    Ronan
  1. New Alloys offset?
    By r2sma in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-04-2012, 11:49 AM
  2. Offset Alloys
    By micalee in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-12-2008, 08:30 PM
  3. Alloys help!!! Offset.....
    By ss.raju-golf4 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-03-2008, 10:33 AM
  4. offset for 18"alloys for new audi tt 3.2
    By panttman in forum TT - 8N Forum - 1998 - 2006
    Last Post: 18-03-2008, 06:47 PM
  5. new tt 3.2 offset for18" alloys
    Last Post: 17-03-2008, 07:01 PM
