Thread: ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
Results 1 to 8 of 8
  1. ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    S Wales
    My car is currently stuck down my mams dodgey lane for the night as I cant get it moved due to no steering.
    Sequence of events:
    It's been starting to get a bit tempremental for a while now, but nothing worth following up. It's had a few starty-upy issues (no 'ummmph'). I know the glow plugs need doing (I have them planned for this weekend) and have tested the battery, 12.5v.
    Today:
    I drove to work at 6am, car started fine in about 8degrees. At 10am, I went to McDonalds for brekkie as there's no canteen on a Sunday. On returning, about 15mins later, I had to stop at a barrier to key fob back in. Then the car wouldnt turn over. Next to no response when turning the key. This happened for 9 attempts then on the 10th, it turned over and I got to a parking space.
    After work, the car fired up first time and I got home.
    Roughly an hour later, I went to go shopping. This is the first case of the RED steering wheel light and 3 x beeps, car started first time. No steering power at all, almost locked. I cut the engine off and put it straight back on, it fired up no issues, but then an orange steering wheel light stayed with me for the duration of the run. After shopping, same again, RED > off > on > yellow. Drove away.
    After going to my mams for Sunday dinner, im now stuck with the red light and no steering. Car is paralised. Engine fires up every time, but with a red light and 3 beeps.
    Any advice on what it is or how to move my car so I can get it to a garage?
    Thanks in advance, applogies for the sketchy description.
  2. Re: ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    S Wales
    Is it worth me just changing the battery? Can a battery 'not work' even though its showing 12.5v on a multimeter??
  3. Re: ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    S Wales
    Wow, this forum has gone slow...
  4. Re: ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    mjhamilton Guest
    would it be worth getting the code read - this would probably narrow down the issue
  5. Re: ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    S Wales
    Bump
  6. Re: ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    46 Post(s)
    Quote Originally Posted by Stuart_B View Post
    Bump
    Did you do what MJ advised and get it scanned for faults?
  7. Re: ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    Pembrokeshire
    22 Post(s)
    sounds like a dodgy earth cable. this may be causing a lack of power to the steering motor ? a code read is required first though, or just check each earth in turn. you would be best getting it recovered to a garage.
  8. Re: ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    Southern County Softy
    20 Post(s)
    A3's have an issue the electric motor on the rack. Code read it first but I suspect you will need a new rack/motor/loom
    Sent from my GT-I9305 using Tapatalk now Free
    A4 2.5 tdi QS (mapped)
  1. Please Help battery flat so i jumped the car red power steering light on wont come off
    By j1981 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-10-2012, 07:21 PM
  2. Tracking, steering wheel and the ESP light
    By JGP in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-07-2011, 07:07 PM
  3. Replies: 4
    Last Post: 21-07-2010, 09:10 PM
  4. Steering wheel locked - Help!
    By Desperatedad in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 10-06-2009, 01:41 PM
  5. Can the steering column cowling be removed without removing the steering wheel?
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-04-2008, 06:48 PM
