Thread: Vagcom login codes !!!!
Results 1 to 10 of 17
  1. Vagcom login codes !!!!
    Bristol
    I notice you have to enter a login code to access certain vagcom modules and its area's
    I wanted to get into the service module which is " engine adaption 10 " if i remember correctly , but need a log in code to access the service section
    I have full version of vagcom
    Ive tried the 12233 login that gets you in some other modules
    Can anyone help with log in codes for certain modules?
    MK5 Golf TDI 2.0ltr GT Sport in Black
  2. Re: Vagcom login codes !!!!
    Mar 2007
    Greater Manchester
    I remember I had a problem resetting service reminder from channel 10, can't remember if it asked for login code. Anyway I used a different channel. Think it was 02 or 45
    look here
    http://www.ross-tech.com/vag-com/cars/vw_sri.html
    2001 Bora TDi PD 115 (AJM)
  3. Re: Vagcom login codes !!!!
    Bristol
    cheers loofer for reply
    i been usinghtat ross link to try and do it , but cant get into the channel without a login code
    so maybe i will try channel 2 or 45 then m8 ?
  4. Re: Vagcom login codes !!!!
    May 2007
    knee deep in clunge
    14 Post(s)
    if you are trying to reset the service indictor you must do it via dash insert select 17 then adaption 10 channel 2 and change the value to 0 and save.12233 is for engine ecu settings for egr and fuel and timing as i have posted on here for pd fueling issues
  5. Re: Vagcom login codes !!!!
    london/ UK
    Try www.openobd.com as it will give you few more options, also, a search on tdiforum.com will bring somme as well !
  6. Re: Vagcom login codes !!!!
    Bristol
    cheers guys will give it a go tomorrow hopefully !!!
  7. Re: Vagcom login codes !!!!
    Bristol
    Quote Originally Posted by a8 tech View Post
    tried iot today, no luck !!! says channel not available !!!
    also ch 45 is a no go too loofer !!
    dam are sharans that different cos i have a few modules missing too , that most other VW,s have !!!
    im using a ebay special cable , could this be the problem ?
    has anyone got any other ideas pls ?
  8. Re: Vagcom login codes !!!!
    May 2007
    knee deep in clunge
    14 Post(s)
    check what version vag com you have
  9. Re: Vagcom login codes !!!!
    Bristol
    its 409-1s a8
  10. Re: Vagcom login codes !!!!
    Bristol
    Quote Originally Posted by cbrpaul View Post
    its 409-1s a8
    using DB9 RS232 port interface Cable (KKL VAG-COM)
  1. vagcom codes.
    By M4YTY in forum Chat - Completely Off Topic
    Last Post: 24-05-2007, 09:29 AM
  2. VAG COM Login codes
    By Dune in forum Audi A4 - Archive Topics
    Last Post: 10-05-2007, 11:34 PM
  3. Login Code
    By jamie211983 in forum Passat - Archive Topics
    Last Post: 22-04-2007, 12:30 PM
  4. vagcom codes from my mk4 golf help
    By dreamworx in forum Golf MK4 - 1999 - 2004
    Last Post: 23-11-2006, 03:14 PM
