Thread: Engine oil capacity - 1.9tdi DPF or not?
Results 1 to 10 of 15
  1. Engine oil capacity - 1.9tdi DPF or not?
    Nov 2008
    I have a 2008 1.9tdi se estate. The engine oil capacity is either 3.8 litre (non DPF) or 4.3 litre (with DPF).
    How can I tell whether mine has a DPF or not?
    Also out of interest why is the capacity different - and if the DPF was originally fitted and then removed would this reduce the oil capacity requirement?
    Thank you for any advice.
  2. Re: Engine oil capacity - 1.9tdi DPF or not?
    46 Post(s)
    Is your car £30 to tax? Check the option codes in the spare wheel well on the sticker and put them into here - http://igorweb.org/equidec/
  3. Re: Engine oil capacity - 1.9tdi DPF or not?
    Nov 2008
    Thanks for this; very helpful.
    The car is £125 to tax - does this mean it is not DPF for definite - or do I still need to check the options codes?
  4. Re: Engine oil capacity - 1.9tdi DPF or not?
    46 Post(s)
    My A3 1.9 has a DPF, it's 2009 and £30 to tax. The non-DPF model of the same year is £125.
    Check the codes anyway, it probably doesn't have one but check via the codes.
  5. Re: Engine oil capacity - 1.9tdi DPF or not?
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    One easy way to check if your car has a DPF is that if it has, then there will be a DPF warning light on the dash display. you can check in your car manual what this looks like.
    Skoda Octavia II SE 1.9PD TDI
  6. Re: Engine oil capacity - 1.9tdi DPF or not?
    Kinross Scotland
    What is your engine code ? i.e. BKD ,BLS ect. find it, post it, and we will tell you from there. My Golf was a 1.9TDI Match 2008/2009 and it had a DPF, engine code BLS and it was £125 to Tax.
    Tiguan 2.0 4Motion 140PS 01/07/2013
  7. Re: Engine oil capacity - 1.9tdi DPF or not?
    46 Post(s)
    Quote Originally Posted by richard@thebrae View Post
    My March 09 A3 1.9 BLS with DPF is £30? OP check your codes and report back.
  8. Re: Engine oil capacity - 1.9tdi DPF or not?
    Kinross Scotland
    Hi my 1.9TDI with DPF Jan 2009 had a DSG box and the emission's value was 137grms so it must have been tipped over the tax price band by the DSG Box. (bu** er)
  9. Re: Engine oil capacity - 1.9tdi DPF or not?
    46 Post(s)
    Ah mines manual you see that's why then.
  10. Re: Engine oil capacity - 1.9tdi DPF or not?
    Nov 2008
    Thanks for the help much appreciated. I did check for the warning light last night - and there is not one. The engine code is BXE and the emissions are 137g/km - it is a manual gearbox. I am pretty sure this is non DPF (happy days) but will check the options codes later as well.
    On a separate note I will need to buy new discs and pads in the not too distant future - I looked at Pagid on Euro but there are 3 different sizes (280, 288 and 310mm) for the front and two for the rear - all listed for my reg. Is there a way to tell what is fitted to my car without taking the wheels off and looking?
  1. 2.0tdi 170 bhp bmn engine code oil capacity
    By sbt in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-12-2012, 12:06 PM
  2. audi a4 2.7 tdi engine oil capacity
    By big jase in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-07-2011, 05:45 PM
  3. Question Engine Oil Capacity
    By paddyjoesoap in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-11-2010, 10:53 PM
  4. engine coolant capacity golf 1.9tdi sport
    By ccs in forum Golf MK5 - 2004 - 2009
    Last Post: 01-09-2010, 10:46 PM
  5. engine oil capacity?
    By chrisvrscrx in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-04-2009, 02:46 PM
