Thread: Electric window problem Mk V Golf
Results 1 to 10 of 13
  1. Electric window problem Mk V Golf
    Sep 2007
    First post so be gentle, drivers' side electric window, when I'm stationary, if I "wind" the window up, it stops just before the top and winds itself back down halfway. Dealer checked it under warranty and said it was ok... Anyone else have this problem ?
  2. Re: Electric window problem Mk V Golf
    Mar 2007
    B
    Sorry.
    But if you can show your dealer it happenning then he can't truthfully say it's ok. I take it the problem is intermittent?
    Does the window stop and wind back if you block it from rising? Newer cars sense the increase in motor power demand if something is blocking it (like your arm).
    It might just be some obscure fault that happens when some random event causes electronic noise - hard to find, prob why your dealer would rather look the other way.
  3. Re: Electric window problem Mk V Golf
    Dec 2006
    Newcastle
    Quote Originally Posted by dekerfintheshed View Post
    I had a similar problem with my MK5 golf. If I pulled the switch to have the window come all the way back up it would end up going all the way back down. Took many visits to the dealer to eventually get it sorted, in which time they changed the motor, switches... the list goes on.
    After the final 'fix' I dragged the mechanic out to show that his handiwork still hadn't fixed the problem. It turned out that all it needed was for the door 'skin' to be removed & have something done to it- apparently the window was sensing too much friction when going up so it was dropping back down. Worked perfectly ever since!
    Hope this helps
  4. Re: Electric window problem Mk V Golf
    Aug 2007
    Thanks I have the same problem.. they said nothing wrong with it the first time.. now back for the second time as Im determined to get them to fix it.
  5. Re: Electric window problem Mk V Golf
    I have this problem on drivers window. When you motor the window down half way and try and one shot it up, it morors down! Also does it using the remote role back function. I think its the controller, i have booked it in the VW dealers so will keep you posted.
  6. Re: Electric window problem Mk V Golf
    Dec 2006
    Newcastle
    Quote Originally Posted by bobster107 View Post
    Hopefully it'll be a quick fix for you. Mine had numerous motors and at least one control unit replaced before it was suggested that the door skins were causing too much friction and causing the window to roll back down as a safety mechanism. If they don't fix it first time suggest they take a look at the door skin & hopefully get it sorted out for you a lot quicker.
    Mine has been fine since!
    Paul
  7. Re: Electric window problem Mk V Golf
    Jun 2008
    I had the exact same problem with my Mk5 GT TDI. The window would close but then open again halfway.
    Try running a cloth with some soap or washing liquid around the inside of the door trim where the window slides shut. There may be something stuck in there which is obstructing the window mechanism and causing the window to open automatically.
    Sounds strange but it worked for me.
  8. Re: Electric window problem Mk V Golf
    Nov 2008
    hi, this is my 1st entry. my wife parked the car in driveway, when i got in the car later found drivers and passengers windows halfway down, and it had been raining. i swore it was my wifes fault.i now have to appolygise
  9. Re: Electric window problem Mk V Golf
    Apr 2012
    malta
    i have the same problem, and will try to clean where the window shut,
    thanks
  10. Re: Electric window problem Mk V Golf
    Kinross Scotland
    Quote Originally Posted by mickybouy View Post
    There may be another explanation for you. Same thing happened to me twice within 1st month of ownership, the second time i saw it happen and it was caused when i knelt down to look at my daughter's rabbit. Cause was the key fob being pressed within my pocket. When you press the unlock button for several seconds the windows come down.
    Tiguan 2.0 4Motion 140PS 01/07/2013
  1. A2 Electric Window Problem
    By PeterC in forum A2
    Last Post: 29-05-2010, 07:39 PM
  2. Golf mk3 electric window problem
    By iaindhill in forum Golf MK3 - 1993 - 1999
    Last Post: 21-03-2010, 05:07 PM
  3. Electric Window Problem
    By mattbrew1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-08-2007, 04:39 PM
  4. Electric window problem!
    By HappyS3Owner in forum Audi A3 - Archive Topics
    Last Post: 02-08-2007, 04:57 PM
  5. Passat Electric Window Problem
    By Brianm in forum Archive posts
    Last Post: 05-02-2007, 12:30 PM
