Thread: Brake and Air Bag Warning lights after jump starting.
Results 11 to 20 of 24
  1. Re: Brake and Air Bag Warning lights after jump starting.
    130 Post(s)
    1972 Post(s)
    Failure of the nearside ABS/pad harness is common. Bridge the connections out at the inner wing terminal blocks behind the grommet.
  2. Re: Brake and Air Bag Warning lights after jump starting.
    Selston, Nottinghamshire
    Is that the wheel off... again . Or am I being stupid... :/
    Sent from my GT-I9305 using Tapatalk 2
    History of V.A.G. Cars Owned:-
    2001 A4 Avant SE AJM 1.9 TDI -2011 A4 Avant SE 140PS 2.0 TDI - 2005 BXE VW Passat 100PS Highline 1900 TDi - 2006 Touran 1900TDi 105PD - 2003 Audi A4 1.9TDI Avant Quattro Sport
    2003 Audi A4 1.9TDI Saloon Quattro Sport - 1983 VW Golf GTi 1800 Mk1 - DX - 1978 VW Golf GTi 1600 MK1 (LHD Import) - EG(00004) - 1978 VW Polo N
  3. Re: Brake and Air Bag Warning lights after jump starting.
    Ah... found it... wheel off... but still theres light.. will do drivers side now.
  4. Re: Brake and Air Bag Warning lights after jump starting.
    130 Post(s)
    1972 Post(s)
    At the black connector location you will find a brown/green wire, if you earth this the light should go out. If not, remove the left lower A pillar kick panel and locate the 17 pin green connector, at position 3 the brown/green goes from there to the dash.
  5. Re: Brake and Air Bag Warning lights after jump starting.
    Black connector? I'm slightly lost.. do you mean the connector behind the wheel just throughout the grommet? Also.. in the LH a pillar, the nly green connector has two wires. Which is situated kn the second row down.
  6. Re: Brake and Air Bag Warning lights after jump starting.
  7. Re: Brake and Air Bag Warning lights after jump starting.
    #17
  8. Re: Brake and Air Bag Warning lights after jump starting.
    #18
    Ah... so I put my multimeter I to AMP mode and stuck one cable into the brown side of the plug and held the other onto a good earth point... the brake disk.. and hey bingo bango the clocks now say OK...
  9. Re: Brake and Air Bag Warning lights after jump starting.
    #19
    So has tha done a reset or does that mean I need to replace the wiring from the connector to the pad and abs??
  10. Re: Brake and Air Bag Warning lights after jump starting.
    #20
    Hmm. I guess I need to present an earth to the other wire..
  1. Air bag warning light
    By autobrake3 in forum Golf MK6 - 2009 - 2013
    Last Post: 04-12-2009, 06:56 PM
  2. Air bag warning
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-04-2008, 06:50 PM
  3. Air bag warning light
    By pesky in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-12-2007, 11:44 AM
  4. Air bag warning light, Brake warning light
    By michaelboyd49 in forum 80 - 90
    Last Post: 30-11-2007, 09:50 PM
  5. air bag warning light ?@???
    By chrissgoduk1985 in forum Archive posts
    Last Post: 19-06-2007, 06:20 PM
