Thread: Starter motor failure ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. Starter motor failure ...
    Sep 2011
    Lurking over a keyboard ...
    On Saturday my car failed to start , all I heard was very tiny clunk sitting in drivers chair with all windows up no music or fan going.
    On the fourth cycle of key she started , no long crank, no noises other than normal operational sounds.
    There was no dimming of dash or any cut out of MMI for the failed 3 starts, battery is showing 12.1v/80% SOC in VCDS, NO DTC's in VCDS ...
    On Sunday my car failed to start , same info as above but car started on second cycle of key.
    Today no such issues, is my starter motor going to fail?
    After a good summer with no issues (finally!) is my winter of woe on me again! ...
    I really do hate my car! ...
    It is the biggest pile of poo! ...
  2. Re: Starter motor failure ...
    46 Post(s)
    Quote Originally Posted by gupsterg View Post
    Yes sounds like starter, a friend who had* a 2001 Mondeo, the starter started failing and clunked randomly and be morning it kept clunking and wouldn't start. New starter and new battery sorted it.
    *had as in the engine swallowed its intake flap things and threw a conrod out of the engine
  3. Re: Starter motor failure ...
    Jul 2013
    76 Post(s)
    It sounds like the main contacts on the pull in solenoid maybe on there way out.
    You would have to see if the solenoid feed wire was being energised when you turn the key.
    If so, then if not a loose connection or bad ground then its the starter.
    Dan
  4. Re: Starter motor failure ...
    Sep 2011
    Cheer's Chris for info, exchange starter motor cheapest I can find for a 3.0 TDi V6 is £252 + deposit = £300 . Audi dealer is coming in cheaper , my fear is the flipping thing is gonna give up the ghost right when I need it the most!
    Cheer's Dan for info, I only did an oil change a week ish ago and as my car is such a delightfully reliable A6 (NOT!) I checked everything like connections of things, any leaks, etc , etc whilst underneath it. I believe it is an energising issue as for the rest of the day all is well.
    Ahh well I really can't wait till the day comes she leaves me or perhaps I should consider getting her crushed! ...
  5. Re: Starter motor failure ...
    46 Post(s)
    Get it refurbished? My friend got his refurnished by a local company and came back as new and only cost <£100, think it was £70
    2 1 0
  6. Re: Starter motor failure ...
    Feb 2009
    West Yorkshire
    10 Post(s)
    My thoughts are with you Gup. But don't get rid...who would we ask for help
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  7. Re: Starter motor failure ...
    Jul 2013
    76 Post(s)
    Before you do anything measure the voltage on the battery.
    Whilst cranking over as if this drops to below 9.6v the battery just may need a recharge, how long has it been on the car?
    You could have drained it when working on the car .
    1 1 0
  8. Re: Starter motor failure ...
    Sep 2011
    I just got new battery in Jan 13, Bosch one 110Ah had also a very new manufacturer date stamp, it is coded correctly to battery regulation module.
    My wife laugh at me each time I put the car on maintenance charging when any car we've ever owned in 17 years has never had it done and we drive this the same as others.
    I also feel my neighbours must think can't that **** next door afford a new battery when I'm recharging it!
    And don't ask how many new parts this car has had in 2yrs of me owning it, I got it with 70K on the clock only recently touched 88K ish ...
    If I took out the retrofits and accessories I have spent in excess of £4.5K on parts/maintenance ...
    But I will check battery with multimeter and when cranking occurring tomorrow for first start of the day, so far fault only occur on first start of the day ...
  9. Re: Starter motor failure ...
    Feb 2009
    West Yorkshire
    10 Post(s)
    That's when it has been stood over night and can lose its charge if it has a dead cell. Check it out..if it is no good then claim on its warranty but check charging voltage too
    1 1 0
  10. Re: Starter motor failure ...
    Sep 2011
    Well check that option out chap , glad I posted thread as that train of thought had not registered in my brain! LOL!
    Quote Originally Posted by Lukenkarl View Post
    Thanks for support & thoughts on issue and will do checks mate ...
  1. What starter motor do i need?
    By Rynomite in forum Golf MK3 - 1993 - 1999
    Last Post: 27-03-2012, 06:03 AM
  2. Starter Motor?
    By timjon in forum Golf MK3 - 1993 - 1999
    Last Post: 29-12-2010, 12:56 PM
  3. How To starter motor
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-08-2010, 05:30 PM
  4. Please Help Non starter - suspect starter motor.
    By 94golfcl in forum Golf MK3 - 1993 - 1999
    Last Post: 18-01-2010, 10:09 AM
  5. Starter motor
    By schteeeeveeee in forum Audi A3 - Archive Topics
    Last Post: 24-01-2008, 04:32 PM
