Thread: Audi A4 Roof Flashing Light
  1. Audi A4 Roof Flashing Light
    Jul 2012
    Middlesbrough
    im sure this has been posted before but i cant seem to find a thread related to my problem (there are similar)
    My roof warning light is flashing when i first turn the ignition on, the roof itself opens and closes fine using the electric button, i've tried opening and closing manually but no luck
    any ideas?
    also do i need to do the manual open and close using the key with the ignition on? i did it with it off and just curious to make sure im doing it right
  2. Re: Audi A4 Roof Flashing Light
    46 Post(s)
    The flashing roof sign might be the big thing (sorry can't think of the exact word!) in the boot which you have to flick left->right or right->left, I think it's some kind of lock?
    If its working fine I wouldn't be worrying and again with the manual release, if its working fine without the key in the ignition then wouldn't worry.
  3. Re: Audi A4 Roof Flashing Light
    Jul 2012
    Middlesbrough
    yeah i know what you mean! will have to look up see which way its supposed to be
    it only came on after the garage had fitted a new bit of windscreen trim, the black part of mine flew off when doing 70...ish on a motorway... so im going to take it back to them and try and get them to sort it or atleast put it on a scanner for free
  4. Re: Audi A4 Roof Flashing Light
    Jul 2012
    Middlesbrough
    just read up what that handle is for, its just for the shelf in the boot to be either lifted or lowered to give you more boot space, so cant be that, trip to the garage it is to sort since its only came on after theyve had it!
  5. Re: Audi A4 Roof Flashing Light
    46 Post(s)
    Ah I thought it locked something in place
    Yep get them to sort it, a fault code scan will show any fault.
  1. Please Help Audi A4 170 TDI coil light flashing
    By Dhiren in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-06-2014, 04:15 PM
  2. A3 Cabrio roof warning light flashing on start up
    By vb2111 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 17-05-2012, 01:21 PM
  3. Please Help Dashboard lighting problem - roof light flashing, no parking brake light etc
    By 95cabrio in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 14-12-2011, 07:21 PM
  4. audi 53 plate esp light on abs light on handbrake light flashing
    By craigq in forum Chat - Anything with wheels
    Last Post: 03-09-2011, 08:58 PM
