Thread: Does Mk7 Golf have a timing belt or chain?
Results 1 to 10 of 11
  1. Does Mk7 Golf have a timing belt or chain?
    Apr 2012
    N. Ireland
    There is a lot of issues with chains breaking in bmw diesels. I am a high mileage driver who likes to keep a car for a good while. Can anyone tell me has the new mk7 golf got a timing belt or chain? I was thinking of buying a mk7 golf. I was thinking of phoning a vw garage to ask but i thought i would try the forum first.
  2. Re: Does Mk7 Golf have a timing belt or chain?
    46 Post(s)
    I'm pretty sure most if not all diesels are belts.
    Stick to 60k/4 years whichever comes first.
  3. Re: Does Mk7 Golf have a timing belt or chain?
    North Shields, UK
    Don't the TDIs now have a belt that is supposed to last the life of the car and not need replacing (with no official recommended timelines for replacement)?
    Thought the 2.0TSI engine had a chain - the Scirocco/MK6 Golf GTI 2.0TSI 211PS engine does.
  4. Re: Does Mk7 Golf have a timing belt or chain?
    Apr 2011
    Sunderland, UK
    no belt will last the lifetime no matter what vw say. even if they say it does I still wouldn't trust them!
  5. Re: Does Mk7 Golf have a timing belt or chain?
    North Shields, UK
    Quote Originally Posted by mcmaddy View Post
    I don't trust them, but VW seem to have the confidence to remove it's compulsory replacement from their service schedule for 2.0TDIs fitted to MK7 Golfs. As a matter of caution i'd probably want it replaced at 80k miles even if it is supposed to last as long as the rest of the car.
  6. Re: Does Mk7 Golf have a timing belt or chain?
    Jul 2010
    Durham England
    Quote Originally Posted by maisbitt View Post
    The last Golf I had with a belt cam drive was a Mk4 1.6 petrol match that initially had only a service inspection for the belt & renewal was at something like 125k..............then all of a sudden the belt had to be changed at 40k for all cars !!
    Whats the betting this happens again, or is it just the cynic in me thinks this
    D
    1.6 DTI Blue Motion Technology, DSG, Pacific Blue Metallic.
  7. Re: Does Mk7 Golf have a timing belt or chain?
    Apr 2012
    N. Ireland
    Lifelong belts may sound impressive but I am keen to learn (a) the cost of a replacement belt and (b) the location of the belt under the bonnet.
    There is a lot of info online about the problems and expense replacing diesel bmw 'lifelong' timing chains esp since the BBC Watchdog episode highlighted this in June this year. BBC One - Watchdog - BMW deny engine failures are due to manufacturing fault
    Therefore could anyone find out the cost of the timing belt for a 2.0TDI Mark 7 Golf and if it is much dearer than a typical timing belt?
    Also how handy are they accessed under the bonnet as an 'engine out' job like the bmw will be a major additional expense?
    Thanks all for the replies to date.
  8. Re: Does Mk7 Golf have a timing belt or chain?
    Up North
    Hmmm. This one makes me ponder.
    When looking to swap my CR engined Passat I made enquires on the Audi part of the site about the current diesel engines and was told that they were now chain driven, which suited me just fine.
    I've had a cam belt go on me many years ago, I still have the bad back from taking out the engine for a complete rebuild and the bent valve sits proudly on top of my monitor alongside the piece of MG aluminium head I had to literally saw in half to separate it from the block. But that was caused by stones thrown up into an exposed bite on a newly surfaced road. Protection is a bit better nowadays.
    In principle I'm happy with the idea of a belt, but not one that needs changing every 4 years irrespective of mileage. I did a lot of research - WV and Lada were the only marques pulling this stunt. I've just (very reluctantly) had the belts done at 6 years on my Golf and the wife's car at 16k and 11k respectively. It's a massive, money making con!
    The BBC watchdog programme was about BMW chain drives at the rear of the engine, which is just about the most stupid place I can imagine to fit one. A replacement is an engine out job so no-one is ever going to be tempted to do a precautionary swap. Honda and others seem to make a chain last for intergalactic mileages so I don't see why the Teutons can't do the same.
    A chain must be better than a belt every 4 years. So I'd settle for a belt that needed changing at 80k or 10 years. Or a chain at the front of the engine that I can change myself at about the same frequency. Anything else is just pants.
    By the way, a belt swap and new water pump using VW OEM parts was £280 at a very good VW only indy that I would recommend to anyone. Dealer price was about £430 IIRC. I can't see if being much different on a Mk 7
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  9. Re: Does Mk7 Golf have a timing belt or chain?
    Jan 2013
    Slough
    Teflon.
    Couldn't have put it better myself. Spot on.
  10. Re: Does Mk7 Golf have a timing belt or chain?
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    VW have had significant problems with chains fitted to the 1.4TSI engine . Many owners are faced with replacing complete engines (£6K +) with little contribution from VW if outside the 3yr warranty, because of quality problems with the chain supplier.Try googling the VW 1.4 chain problem.
    Skoda Octavia II SE 1.9PD TDI
  1. Timing belt or chain?
    By Beardy_Bear in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-07-2013, 10:33 AM
  2. timing chain or belt?
    By ckings6056 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-01-2012, 02:16 PM
  3. timing belt or chain?
    By stevo-dtm in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-05-2010, 01:10 PM
  4. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  5. MK 5 Golf timing belt or chain
    By missilemary in forum Golf MK5 - 2004 - 2009
    Last Post: 03-05-2009, 08:39 PM
