Thread: Adblue
Results 1 to 10 of 14
  1. Adblue
    Aug 2013
    UK Hull
    As title....is this implemented on the B7 Passat?
    I have the Passat BMT Estate 2.0l tdi and the book mentions Adblue additive..
    Confusing....
  2. Re: Adblue
    Sep 2008
    chester
    17 Post(s)
    Use that in my truck,surely they're not putting it in cars,another expensive con if they are!
  3. Re: Adblue
    46 Post(s)
    i think its only small amounts in certain cars, your service book states when it needs changed.
  4. Re: Adblue
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    I'm certain that it is not used in the B7 Passat to date.
    1 1 0
  5. Re: Adblue
    Aug 2013
    UK Hull
    Quote Originally Posted by 32110 View Post
    32110,
    Thanks for that ...If there is one criticism I have of VW it is the generic manual they provide.......A friend of mine has the Sharan that uses Adblue and the story he told about it was not good....
  6. Re: Adblue
    Mar 2009
    staffs
    The adblue will need topping up in your car every 10k or sooner depends how you drive it im sure its located in the boot on the os.It will let you no when its low you will get a warning on the mfd. From what iv read on here you cant just top it up yourself ..well you can but you have to get a nice person with a vag com to tell the car that's it been refilled ((
    2006 tdi s jetta reflex silver
  7. Re: Adblue
    Wirral, Merseyside
    B7 Passats in UK do not use adblue.
  8. Re: Adblue
    Sep 2011
    Lurking over a keyboard ...
    Are you sure? Link:- Think Blue. : Volkswagen UK
    I will checkout this info but they are usually spot on ...
    Link:- VW Touareg DPF and Audi Q7 DPF filter FAQ and Adblue fluid FAQ
  9. Re: Adblue
    Aug 2013
    UK Hull
    Well, there's nothing like that in the boot area of my Passat Estate.....where ever I look...????
  10. Re: Adblue
    Sep 2011
    I do have an answer, the answer will be be better if you check your service book and give me the engine code from the data sticker. The 4 letter engine code will allow me to tailor my search better to give you an answer ...
  1. Adblue
    By kerrglen in forum Q5
    Last Post: 01-12-2012, 12:23 PM
