Thread: Engine management light on with no loss of performance, tick over higher.
Results 1 to 10 of 13
  1. Engine management light on with no loss of performance, tick over higher.
    Jul 2007
    somerset
    8 Post(s)
    Hi, as per heading really, driving my 1.8 T BEX eng code the other day and the engine management light came on, there was no loss in performance and no mis fire, drove it 100 miles or so, got home and disconnected the battery, when reconnected and started the light was out, drove 70 miles the next day with the light still out, although I did notice the tick over was a bit higher sometimes, it would tick over at 800 revs as normal, then at the next set of lights would tick over at 1000' and so on.
    Today the light has illuminated again, still no loss in performance and still an irregular tick over, some times it feels a bit lumpy as if its missing but it's not.
    Any input will be great, I suspect some sort of air valve or a air mass meter issue, gonna get it scanned tomorrow and see what that brings up. but in the meantime if anyone has had the same issue please feel free to elaborate.....Ta.
  2. Re: Engine management light on with no loss of performance, tick over higher.
    Pembrokeshire
    22 Post(s)
    cts maybe
  3. Re: Engine management light on with no loss of performance, tick over higher.
    Jul 2007
    somerset
    8 Post(s)
    Sorry, what's cts!
  4. Re: Engine management light on with no loss of performance, tick over higher.
    46 Post(s)
    coolant temperature sensor
    your fault scan should tell you tomorrow
  5. Re: Engine management light on with no loss of performance, tick over higher.
    Jul 2007
    somerset
    8 Post(s)
    Ah of course, I assume this would be the green one at the back of the engine, new o ring and clip also required if this turns out to be the problem.
    my temp gauge reads crack on 90 degrees though, would that be right......
  6. Re: Engine management light on with no loss of performance, tick over higher.
    Jun 2006
    Cardiff
    The CTS has 2 seperate outputs. One to the gauge & the other to the ECU, it's common for one output to fail without effecting the other.
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
    1 1 0
  7. Re: Engine management light on with no loss of performance, tick over higher.
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Only buy e-bay cheapo if you want to do the job again in the near future.
    The genuine Audi part complete with new clip and o ring is only £40, been there, done that. 1.8t AVJ code
    Stuart
  8. Re: Engine management light on with no loss of performance, tick over higher.
    london/ UK
    There is a throttle body adaptation to be made, you need fully registered vag com/vcds in order to perform basic settings though !
  9. Re: Engine management light on with no loss of performance, tick over higher.
    Jul 2007
    somerset
    8 Post(s)
    Hi again, thanks for the info so far.
    Right had the scan done this morning and came up with the following Fault Codes:-
    16891 (P0507) Idling speed control, revs above specification sporadic
    17544 (P1136) Bank 1, Additive mixture adaption system too lean Sporadic - MIL ON
    18010 (P1602) Power supply terminal 30 voltage too low sporadic - MIL ON
    16804 (P0420) Bank 1, Catalyst system Efficiency too low sporadic - MIL ON
    ok, so a few fault codes which i guess are probably linked to one problem, the 1801 power supply terminal 30 voltage too low i assume is battery related and probably due to me disconnecting the battery to turn the emissions light out.
    The scanner did say it could be down to cheap supermarket fuel or an air leak somewhere, and to fill up with some decent esso or shell and to take it back for another scan in a week or so, he did clear all codes and re-set the throttle valve position as i removed this last year to replace the alternator pulley. So far today the light has stayed off but i dont expect it to stay out for too long.
    Can any one descipher the codes that we have, thanks, Rhen.
  10. Re: Engine management light on with no loss of performance, tick over higher.
    Jun 2006
    Cardiff
    It may take a few driving cycles for the EML to come back on.
    I would advise that you get your scanner/mechanic to look at the temp the ECU is getting from the CTS in VCDS measuring blocks as the ECU won't throw a code if it's getting a signal from the CTS even if it's wrong. Usually CTS failure only causes a code if it's shorted to ground or become intermitent. A goosed CTS will cause the ECU to fuel incorrectly which could well be responsible for your codes. If the CTS is at fault replace it with a genuine VAG part only or you'll probably be buying twice as cheap aftermarket CTS's rarely work properly.
  1. Please Help Engine management light is on, Fan turn on when engine is off, made the battery flat, help
    By shinghu in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2009, 02:15 AM
  2. Golf MK 5, loss of power, juddering, engine management mimic
    By ChefDave in forum Golf MK5 - 2004 - 2009
    Last Post: 08-10-2008, 10:28 PM
  3. TDI Sudden Power Loss! Later higher MPG?
    By TDI-3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 05:32 PM
  4. Engine management light on
    By tonyjmoore in forum Polo - Derby - Lupo - Fox
    Last Post: 26-11-2007, 03:08 PM
  5. Engine management light came on
    By curiousgeorge in forum Audi A3 - Archive Topics
    Last Post: 05-01-2007, 10:27 PM
