Thread: Audi A3 TDI Does not start when fuel less than half a tank
  1. Audi A3 TDI Does not start when fuel less than half a tank
    Aug 2013
    London, UK
    I purchased an Audi A3 TDI 2006 (BKD engine) around 4 months ago and it developed a fault whereby if the fuel level was below half a tank it would not start. This only happens when the car has been left overnight. It cranks fine but it seems it’s not getting any fuel. It can be started with easy start or when the fuel level is raised again to above half a tank.
    I took it to the Audi dealer and they first diagnosed fuel contamination (oil leaking in fuel perhaps?). Tank was emptied, new fuel filter and fuel lines cleared. Got the car back and same thing happened.
    Again I took it to the dealer and they then replaced the in tank fuel pump. Again the same problem occurred with the same symptoms. There are no fault codes or anything and I believe the dealer hasn’t got a clue what’s wrong.
    Any ideas what it could be? I think it’s definitely a fuel issue but what to try next? Could it be a tandem pump issue? I have read these are prone to failures. I have already spent over £900 on this and still no fix so I want to make sure the next thing I do does fix the issue.
    Thanks for your help.
  2. Re: Audi A3 TDI Does not start when fuel less than half a tank
    Pembrokeshire
    22 Post(s)
    welcome
    right, when the tank says its half full, how much fuel is in the tank ? is it actually half full or is it empty.
  3. Re: Audi A3 TDI Does not start when fuel less than half a tank
    Aug 2013
    London, UK
    welcome
    Hi, Its just under half a tank, not empty at all.
  4. Re: Audi A3 TDI Does not start when fuel less than half a tank
    Pembrokeshire
    22 Post(s)
    definately, this has been checked by removing the pick up and physically looking or just brimming the tank and seeing how much fits ?
  5. Re: Audi A3 TDI Does not start when fuel less than half a tank
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    HI, I would be looking at the oil in the fuel problem, as you mention you have had the tank pump replaced, you should be getting an accurate reading.
    The oil in the tank will be causi g some seperation and possibly cause your bad starting.
    Alan.
    VW T6 150 DSG Camper £££
  6. Re: Audi A3 TDI Does not start when fuel less than half a tank
    Aug 2013
    London, UK
    Quote Originally Posted by Alan02 View Post
    Thanks, do you think a leak in the tandem pump can cause oil to mix in with fuel? How else can oil get into the fuel tank?
  7. Re: Audi A3 TDI Does not start when fuel less than half a tank
    Nov 2008
    20 Post(s)
    Your correct on the pump theory, but also the injector seals can pass oil too.
    Alan.
    2 0 0
  1. Please Help Petrol light on at half a tank??
    By ICKY123 in forum Chat - Anything with wheels
    Last Post: 11-06-2013, 12:30 PM
  2. a6 2.0 tdi fuel tank.
    By 1966baz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-04-2013, 09:04 PM
  3. Half tank fuel starvation
    By scottjones924 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-04-2013, 11:07 AM
  4. Please Help Buzzing noise from fuel tank on start up
    By onloantoton in forum Bora - 1998 - 2005
    Last Post: 18-03-2010, 01:01 PM
  5. A6 TDi Quattro Runs out of Diesel at half a tank!
    By dean warren in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-05-2009, 09:46 AM
