Thread: TDC setting with cams out!
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. TDC setting with cams out!
    Mar 2013
    Manchester
    Hi All, my first post here and am just about to get a short piece of rope out!!! Problem is as above, I have cams out, did not lock crankshaft ( was doing leakdown test) now need to lock crank to replace cams. I need to get No1 at TDC or near to use locking pin. No1 glowplug has broken!!! and don't really want to take out injector. As i understand it, the crank moves two pistons to TDC at the same time, if so, which other piston is at TDC at the same time as No1? as i have all other glowplugs out, i can check them easily. Also please try and insult my inteligence/knowledge abd dum it down for me, always better to over explain i think. Also, I live in Manchester, so if there is anyone local that could give me pointers in putting it back together!!!! Thanks in advance Dave
    Last edited by raveydave58; 04-08-2013 at 02:20 PM. Reason: Vehicle, (sorry forgot to mention) Audi A6 2.5 TDI Quattro 2000 AKE engine
  2. Re: TDC setting with cams out!
    Mar 2013
    Manchester
    Sorry, but can't seem to use new paragraph when typeing on here. See! ???
  3. Re: TDC setting with cams out!
    Pembrokeshire
    22 Post(s)
    a v6 i presume ? must be i suppose or you wouldn't refer to cams ?
    if so, then a chap on here, adams24, is a bit of a v6 guru and would probably be able to provide the best advice.
  4. Re: TDC setting with cams out!
    Mar 2013
    Manchester
    Hi Zoll, Yesits V6, and Yep, have tried to msg him but can't as the site seems to say i have no posts! even tho I have posted before! anyway, thanks for reply. I see you can make new paragraphs! Jelous! haha
  5. Re: TDC setting with cams out!
    Engine code required. It is on the ID LAbel in the spare wheel bay. No4 piston will be at TDC with No1. Have you not got a manual. Regards Peter
  6. Re: TDC setting with cams out!
    Mar 2013
    Manchester
    Hi Peter, Thanks for reply, Just edited original post, It's an AKE engine, and thanks for the info, I have a manual if it's in there sorry but not found info.
  7. Re: TDC setting with cams out!
    Ignore the Number 4 that was for a four pot engine. Regards Peter
  8. Re: TDC setting with cams out!
    There is a TDC drilling in the crankshaft directly behind the sealing plug (it is possible to feel the hole).
    WARNING
    To avoid any risk of injury, do not rotate the crankshaft while feeling for the TDC hole with your finger.
  9. Re: TDC setting with cams out!
    Jul 2011
    Norway
    Exactly, the TDC drilling is on the engines left side ( cars left ) and piston no 3 ( cars right side, rear ) will be on top if you get this right, and as Peter said, putting a finger in the hole and then rotate the crank, is a really bad idea
  10. Re: TDC setting with cams out!
    Mar 2013
    Manchester
    Yes, I have the fixing pin in, and the engine still turns, until it comes to a stop, i presume against crank piece that piston rod attaches to. I again presume that when it does lock correctly, it is in a hole/slot in this. No way i want to take any chances tho!
  1. Anyone got any cams for 2.5 tdi?
    By BoyceyS4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-10-2011, 06:38 PM
  2. Tuning a3 1.8t, cams?
    By Alexc11 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 15-08-2011, 10:17 AM
  3. setting a cam to tdc on abc v6 2.6
    By fieldy1978 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-02-2011, 10:00 AM
  4. A6 V6 TDi New cams needed
    By dean warren in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-01-2011, 09:16 AM
  5. cambelt tdc setting marks dohc
    By idcwales in forum Golf MK5 - 2004 - 2009
    Last Post: 09-08-2009, 08:57 AM
