Thread: Sharan Kangaroo Juice
Results 1 to 10 of 10
  1. Unhappy Sharan Kangaroo Juice
    christoff1604 Guest
    Hi, my Sharan has developed a problem with "kangaroo juice" in first and second gear when starting off from stop, it happens all the time and I can only get through it by hitting the gas hard and often this makes the engine go into some sort of "lag" mode with no power, I noticed that if I stop the engine and restart it the "lag" mode hase gone but the jerky start is still there, has anyone else had this problem and do they know a remedy please.
  2. Re: Sharan Kangaroo Juice
    Aug 2007
    Cardiff, South Wales
    Not 100% sure what it sounds like, but to me I think its one ofthe filters ie. diesel filter, or it could be the air intake for the turbo.
    hope it helps
    jordanroch
  3. Re: Sharan Kangaroo Juice
    christoff1604 Guest
    Hi, thanks for the reply, I thought it may be the air flow meter or air filter and I have ordered a new filter to try but I will now check the diesel filter as well, thanks.
  4. Re: Sharan Kangaroo Juice
    Bristol
    Year ?
    Model ?
    Mileage ?
    Last service date ?
    Vagcom access ?
    MK5 Golf TDI 2.0ltr GT Sport in Black
  5. Re: Sharan Kangaroo Juice
    christoff1604 Guest
    Yeah, sorry, info - 52 plate 1.9 TDI Carat, dual climate, all the extras, 79000miles, service in 500miles, I have no vag-com access will a service help if I have it done early (due an oil service) thanks cbrpaul...
  6. Re: Sharan Kangaroo Juice
    Bristol
    Chris 1st thing i would try is get vagcom on it , this will read any DTC,s ( faults ) stored in the ECU , which could save alot of guess work m8,
    What area are you in , someone maybe be close to you with vagcom who is willing to help m8 ,
    Or buy it yourself , can save alot of money in the long if you plan on looking after the car yourself , as I do.
    Failing that try an independant garage with the abililty to read faults.
    Its difficult to say over the net what the problem is m8 ,
    My 1st thought is the maf, but get it read 1st m8 !!!
  7. Re: Sharan Kangaroo Juice
    christoff1604 Guest
    Ive been looking at vag-com cables on ebay but I don't know which one will fit my Sharan ("can, kkl dual line, OBD2 Etc" I live in the portsmouth area if anyone is close and can help, thanks cbrpaul.
  8. Re: Sharan Kangaroo Juice
    Bristol
    email them and ask if it will fit
  9. Re: Sharan Kangaroo Juice
    christoff1604 Guest
    Hi cbrpaul, got a vag-com cable and run test on engine with following results:
    controller: 038 906 019 FC
    coding: 00002
    shop#: WSC 00020
    Vin Number Stuff
    1 fault found:
    17965 - charge pressure control: positive deviation
    P1557 - 35-10 --- intermitent
    readiness: N/A
    What does this mean M8...
  10. Re: Sharan Kangaroo Juice
    Bristol
    chris i did a quick search on that code m8 and a few things came up , this looked worth a read ;
    https://www.vwaudiforum.co.uk/forum/a...p/t-13677.html
    maybe others here might have an idea too ?
  1. VW Sharan
    By mike in forum Touran - Sharan - Caravelle
    Last Post: 14-12-2007, 10:12 AM
  2. Sharan cut out
    By jxs in forum Chat - Anything with wheels
    Last Post: 21-06-2007, 04:46 PM
  3. Which Sharan?
    By happy2 in forum Chat - Anything with wheels
    Last Post: 10-06-2007, 01:23 PM
  4. M Reg 1.8cl kangaroo..
    By gazzer4444 in forum Passat - Archive Topics
    Last Post: 28-01-2007, 05:03 PM
  5. sharan
    By vw007 in forum Touran - Sharan - Caravelle
    Last Post: 24-09-2006, 10:59 PM
