Thread: TT wheels/tyres on an A6?
Results 1 to 10 of 10
  1. TT wheels/tyres on an A6?
    Oct 2010
    Suffolk, UK
    Could anyone confirm whether a set of 17" TT Mk2 wheels will fit an A6 C6 3.0tdi Le Mans?
    The ones in question are 17x8J ET47 5x112 with 225/50 98Y tyres. I'm fairly sure they should be ok but the lack of XL rating on the tyres is making me unsure.
    2013 Mk7 Golf GT 2.0tdi DSG
    2005 A3 Sportback 2.0tdi Sport DSG
    Previous:
    2006 A6 Avant 3.0tdi Quattro Le Mans
    2004 A4 Avant 3.0 (petrol) Quattro Sport
  2. Re: TT wheels/tyres on an A6?
    46 Post(s)
    I think royclark fitted TT wheels on his without any problems.
    I'll be watching this thread as I'm doing the same this year.
  3. Re: TT wheels/tyres on an A6?
    Sep 2011
    Lurking over a keyboard ...
    On A6 4F/C6 centre bore is 57.1mm but peeps have used spigot rings for adapting bore sizes but all below have right centre bore...
    TT 8N alloys is no no as PCD is 5x100 Link:- PCD Audi TT 8N (2003 - 2007) 5x100 wheels | PCD, Offset, Center Bore, mounting and tire size data
    TT 8J is go go RE PCD Link:- PCD Audi TT 8J (2007 - ) 5x112 wheels | PCD, Offset, Center Bore, mounting and tire size data
    TTRS is go go RE PCD Link:- PCD Audi TT RS (2009 - ) 5x112 wheels | PCD, Offset, Center Bore, mounting and tire size data
    So next here are handy calculators RE offset & tyre sizing ...
    Link:- 1010TIRES.COM - Wheel Offset Calculator
    Link:- Tire Size Calculator - Tire & Wheel Plus Sizing
    2 1 0
  4. Re: TT wheels/tyres on an A6?
    Oct 2010
    Suffolk, UK
    Great, thanks Gup!
    Previous:
  5. Re: TT wheels/tyres on an A6?
    Sep 2008
    mostly in the garage
    Quote Originally Posted by UVB View Post
    with 225/50 98Y tyres.... the lack of XL rating on the tyres is making me unsure.
    this crops up all the time.........there is no requirement to have XL on the tyre, the load rating is the number in red.
    If i'm not mistaken you need a minimum of 96 so the load rating is fine.
  6. Re: TT wheels/tyres on an A6?
    Feb 2009
    Glasgow UK
    Had TT Trapeze 17" wheels on my A6 fitted no probs, not a 3.0 Le Mans though to be fair
    1 1 0
  7. Re: TT wheels/tyres on an A6?
    Sep 2011
    Quote Originally Posted by c4a5er View Post
    Hi c4a5er ,
    I go by the sticker in the fuel filler/manuals these stickers differ due to what spec of car is from a discussion in a previous thread also I like to inflate tyre per manufacturer recommendations ...
    A common car size 215/55/16 has a load capacity of 93 which reading of the chart equates to 650kg per wheel. Including the load of the vehicle anything extra including the passengers should not go over the 650kg or 1300kg (calculated for two tyres) over the axle distributed evenly. The same size 215/55/16 also comes in the XL version and this tyre has load rating of 97 which equates to 730kg, hence there is a clear advantage of 80kg per tyre. Generally speaking if you fit the correct size you should have the correct rated tyres but make sure as mentioned above you may need the XL and RF version read the load index rating as well before you make any purchase.
    Above extract from & load rating table Link:- Tyre load index ratings explained and Tyre load index chart
  8. Re: TT wheels/tyres on an A6?
    Oct 2010
    Suffolk, UK
    I fired off an email to Pirelli to check and they came back in half an hour to say that if it was a 98Y then it would be XL and the tyre would be marked as such. Sure enough they were and I have them in my garage now. I'm going to get the alignmemt done before fitting though as the tyres on them are almost new.
    Previous:
    1 1 0
  9. Re: TT wheels/tyres on an A6?
    Oct 2010
    Suffolk, UK
    Got the alignment done yesterday (well, partially...but that's another thread) and have the wheels on. I'm actually quite pleased with the look and dare I say it they suit the A6 Avant better than the TT. One point to mention for anyone else considering it; the existing wheel weights were too high profile to clear the brake calipers. Fortunately the garage I took it to have some low profile weights and a decent balancing machine. It has softened the ride, but not by quite as much as my winter Michelins. I expect this is down to the rubber rather than the half inch difference in rim widths between the two sets.
    Previous:
  10. Re: TT wheels/tyres on an A6?
    Jan 2011
    Stafford, UK
    I fitted TT - 18 x 9 et52 Chris with 145 40 18 97Y Mitchelin pilots.
    As you say Chris, "no problems".
    !7" wheels may be a little close to the callipers.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  1. Question New tyres / new wheels / winter tyres?
    By ash_pearce in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-10-2011, 12:14 PM
  2. wheels and tyres
    By paulsa4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-01-2010, 10:53 PM
  3. Question VW LT 35 wheels and tyres
    By rob20087 in forum The Commercial Range
    Last Post: 23-07-2009, 07:14 AM
  4. wheels+tyres
    By miff in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-04-2007, 01:41 PM
