Thread: Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
Results 1 to 10 of 14
  1. Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    uncleron Guest
    My car is a 2008 A4 Avant 170 S-Line Quattro with 80K miles & still on original & trouble free clutch and over the last few months I have started to hear more & more noise when depressing the clutch pedal - the noise is only there between the first 2 to 4 inches of pedal travel. There is a lot of mechanical / bearing / grating noise coming from the back of the engine / clutch housing now with the pedal at this point - With the clutch pedal in any other position 'silence' !
    It sound akin to a worn clutch release bearing as you can hear it rotating - If I take my foot of the clutch pedal or it’s fully depressed, then I can’t hear it.
    I know the original clutch release bearings were re-designed and there are known issues with Dual Mass flywheels and clutch judder etc but on doing a search on this specific clutch noise I have I struggled to find many people suffering from the same symtoms I have which feels unusual - I can't be alone in this I'm thinking.....
    Anyone else suffered from similar symptoms ?
    Cheers!
  2. Re: Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    46 Post(s)
    Probably your DMF and clutch now need replacing
  3. Re: Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    Mar 2008
    Warwickshire
    Quote Originally Posted by uncleron View Post
    Cheers!
    I'm surprised you haven't found many people suffering from the same problem as it is very common.
    It will be your DMF as you and Chris have suggested.
    Search DMF on this forum e.g. Cost of replacement clutch and Dual Mass Flywheel (2.0TDI)
    You are looking at about £1,000 I'm afraid.
    Audi A6 (C7) 3.0 TDI S Line Quattro 245 Daytona Grey Sep 2013 -
    Audi A4 (B8) 2.0 TDI SE 143 Lava Grey 2008 - 2013
  4. Re: Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    uncleron Guest
    Quote Originally Posted by belly buster View Post
    Thanks for the quick replies guys!
    I did see that the DMF's were an issue - I was just not sure that the noises I am getting with the clutch pedal in the specific initial 4" of travel were definitely related to the DMF's......
    I did have a suspicion - Just wanted to check I wasn't missing anything else it could be I suppose.
  5. Re: Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    Feb 2010
    In the middle
    Agreed. I'm afraid its a DMF and clutch.
    I had the same earlier in the year and yes it is a £1000 job
    A4 (B9) Ultra Sport. 150ps Diesel S-tronic. Glacier White
  6. Re: Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    Oct 2009
    Stirling
    I am curious where you guys can get a clutch and flywheel fitted for £1000?.
    An Audi flywheel is best part of £800
    clutch think was around £300
    labour 300- 500 depending garage.
  7. Re: Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    Feb 2010
    In the middle
    Correction, mine was actually nearer £1200 at a local VAG indy.
  8. Re: Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    Apr 2013
    North Lincolnshire
    Quote Originally Posted by trance View Post
    If you are confident in the workshop, its a lot easier than you think and you can buy a complete DMF & Clutch for under £500, shop around.....Its a big saving if you are willing to get your hands grubby
  9. Re: Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    Mar 2008
    Warwickshire
    You can get equivalent parts without the audi logo on (I believe they are all made by bosch) for a lot less than the audi branded prices.
  10. Re: Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    Oct 2009
    Stirling
    It seems you can make some big savings shopping around.
    So Audi uses Luk for its flywheel, anyone know who Audi use for the clutch kit?
  1. Engine overs revs whilst depressing clutch
    By specialedmick in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-01-2013, 06:53 PM
  2. Question Noise when depressing clutch pedal
    By xtremist in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-11-2011, 08:18 PM
  3. A6 - Depressing clutch to start
    By spacemonkers in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-12-2010, 03:41 PM
  4. Clutch pedal making funny noise!!
    By Sham60 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-09-2008, 08:54 PM
  5. Noise and Vibration through clutch pedal after starting
    By tonyyeb in forum Golf MK5 - 2004 - 2009
    Last Post: 24-04-2008, 03:58 PM
