Thread: Aircon
  1. Aircon
    May 2012
    Durham
    Just a quick question my aircon compressor clutch fell off can I remove the belt or does it drive something else as well engine is awx 1.9 tdi
  2. Re: Aircon
    Feb 2013
    Swindon
    The belt which drives the aircon also drives the alternator and power steering pump so not a good idea. I believe it is possible to fit a shorter belt that leaves the aircon out of the system. A replacement aircon pulley is about £80 but not sure if they come with the securing bolt (which I'm assuming you no longer have).
  3. Re: Aircon
    May 2012
    Durham
    I have two belts on mine just can't tell what else is on the belt with the ac compressor
  4. Re: Aircon
    chester
    17 Post(s)
    If you've got two belts then the comp should drive direct off the crankshaft pulley, just leave it to freewheel till you get the clutch sorted,check its not fell on the undertray.
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  5. Re: Aircon
    May 2012
    Durham
    I won't be getting the air con back on so just wanted to no if I could remove the belt and it didn't run anything else
  6. Re: Aircon
    chester
    17 Post(s)
    Just check and if it runs from the crank to the comp only,its ok to remove it but you don't have to its ok to leave it.
  7. Re: Aircon
    Oct 2006
    Yes the air con belt just runs the air con pulley from the bottom pulley. Why do you want to take the belt off, leave it on, it causes no probs with running of the engine with the drive plate missing.
    I got a new drive plate for mine, as it too had dropped off and wasn't lucky enough to have it resting on the undertray. Came from Germany, £100, bit expensive, but cheaper than a new compressor.
    The clutch is internal, the plate that has fallen off is the drive plate which sits on the blue rubber to cushion the 'take up' when the compressor kicks in. It's the silly little 8mm bolt that holds the plate on that undoes itself thats the culprit.
    A4 Avant 1.9 TDi160 for when the weather is on the damp side - Sold after 9yrs. Now A5 3.0TDI Q Sport Coupe (310bhp/480ft/lbs - Yamaha R6 for when its dry and want some 'High octane Petrol' fun.
  1. Aircon
    By richball65 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-07-2013, 11:40 AM
  2. Aircon
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-08-2011, 06:21 PM
  3. aircon
    By vwturbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-05-2010, 06:29 PM
  4. AIRCON .....Again.
    By Rexer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-05-2010, 09:19 AM
  5. Never liked my aircon.....now its ******
    By The Cobbler in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2009, 10:43 PM
