Thread: Fault code reader
  1. Question Fault code reader
    May 2013
    United Kingdom
    Can anyone recommend a reasonably priced fault code reader that is compatible with a 98 1.9tdi 110? I know this predates the 2004 memorandum on diesels which most code readers have in their blurb but I am correct in thinking the B5's were fitted with OBD2. This would this make it compatible with a code reader??
    cheers
    Arron
  2. Re: Fault code reader
    Slamannan / central Scotland
    Hi Arron
    heres a link to the one I have.
    this reads all vag stuff and 90% of non vag stuff.
    it will even reset the service lights on my 96 A4 1.9TDi 110
    Memoscan U585 CAN OBD2 VAG Diagnostic Code Reader Tool | eBay £74.98
    the VAG cars around the 96 onwards had there own setup not OBD2 but its the same style port some code readers will read them some wont you are better getting one that states VAG
    you do get some cheaper ones but I can highly recommend the above.
    here is a vag only one for change out of £50
    MemoScan VAG5053 VW AUDI Scanner Service Reset VAG 5053 | eBay
    1997 A4 110 TDi Avant Quattro
    2002 Polo 6n2 1.4 TDi
  3. Re: Fault code reader
    Bonny Scotland
    Alternative is a cable from Gendan or the likes (~£20) and VCDSLite from rosstech (free). The free version will give various fault codes, clear historic codes and reset airbag warnings and provides a useful upgrade path if you find the need for more of the software features.
    This setup is what I used for my '99 1.9 tdi and also works on my '04 B6. Don't be tempted by eBay knock-off cables - it's just not worth it.
    Frank
  1. fault code reader?
    By 12bamf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-07-2011, 01:44 PM
  2. fault code reader
    By big jase in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-09-2010, 05:03 AM
  3. Fault code reader
    By 6182marcs in forum Golf MK4 - 1999 - 2004
    Last Post: 04-02-2010, 10:55 AM
  4. fault code reader
    By CHARYBDIS in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-07-2009, 11:13 PM
  5. Fault code reader.
    By frank-59 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-07-2008, 09:28 AM
