Thread: Reset Trip Computer results in speed warning at low speed after start up ?
Results 1 to 10 of 13
  1. Reset Trip Computer results in speed warning at low speed after start up ?
    Jun 2013
    Bristol
    Has any one come across a problem with Speed Warnings just after ignition and start up. The warning symbol is illuminated and lasts about seconds or say about 20 metres driving time. The symbol has a speed signature of '2' presumably the speed at which I was speeding !! It has only just happened after I reset the trip computer to the default settings on the MMI. 2008 A6 2.0tdi mTronic.
  2. Re: Reset Trip Computer results in speed warning at low speed after start up ?
    46 Post(s)
    Go back into your MMI and press CAR, then look for Instrument Cluster and switch the speed warning off.
  3. Re: Reset Trip Computer results in speed warning at low speed after start up ?
    Jun 2013
    Bristol
    Thanks Chris, sorted. Ps no responses on the VCDS query yet.
  4. Re: Reset Trip Computer results in speed warning at low speed after start up ?
    46 Post(s)
    Not yet, I will chase now
  5. Re: Reset Trip Computer results in speed warning at low speed after start up ?
    Jun 2013
    Bristol
    and now the Particle Filter symbol is illuminated and the coil light is flashing, I guess totally unrelated ??
  6. Re: Reset Trip Computer results in speed warning at low speed after start up ?
    46 Post(s)
    Take for a 30 minute drive in 4th @ 60mph if possible.
    Coil light shouldn't be on so a scan is definitely needed.
    I know when my DPF light came on and it didn't go out after doing the above drive, the coil light flashed and then the engine light came on. Turned out it was a DPF pressure sensor, common fault on DPF equipped models.
    What sort of journeys are you doing? If short, consider getting rid of the DPF and getting a remap to suit.
  7. Re: Reset Trip Computer results in speed warning at low speed after start up ?
    Nov 2012
    Somerset UK
    Dave, shame you'd not posted earlier as was in Bristol this morning at Cabots and have VCDS, now back in Burnham on Sea and am aware that there are a few others now closer to you with it.
    Good luck but give me a shout if you need a scan...is only a 30 min drive for you max.
  8. Re: Reset Trip Computer results in speed warning at low speed after start up ?
    Jun 2013
    Bristol
    Chris .... I think a 30 minute drive at 60mph is in order. I am up to London next week anyway. Mark, thanks very much for the offer if it persists I will definitely need it checking (Ps I live in Clevedon) and will arrange a tie up when convenient with you. ?? As an aside the vehicle has a really good ASH (1st 70k) and then fully serviced with a specialist, last service and timing belt change 4k and next service due 13.5k so disappointed with intermittent/ sensitive EMS faults !
  9. Re: Reset Trip Computer results in speed warning at low speed after start up ?
    Nov 2012
    Somerset UK
    Dave absolutely no problem and a mere 20 mins then!
    Strange mine was supplied with absolutely ziltch service history, but no problems whatsoever and initial scan only revealed headlights out of alignment...but it passed it's MOT in May
    Annoyingly my pristine car was scratched in a carpark in Bridgwater yesterday and some scrote scratched the rear with their car/van and didn't leave a note.....grrrr
  10. Re: Reset Trip Computer results in speed warning at low speed after start up ?
    Jun 2013
    Bristol
    I meant to add that my daily commute is c15 miles and avg speed 20mph. I will have a chance to give it long run pretty soon.
  1. trip computer random reset??
    By mrnice in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-07-2012, 09:35 PM
  2. On Board Computer - Average Speed
    By scoobmw in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-09-2010, 10:19 PM
  3. Speed display on Multifunction Highline Computer
    By Golfer Phil in forum Golf MK6 - 2009 - 2013
    Last Post: 16-09-2009, 07:52 PM
  4. Slight noise at low speed - Big vibrations at high speed
    By Stupark in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-09-2009, 08:01 PM
  5. LT46 speed limiter reset
    By charliebucket in forum The Commercial Range
    Last Post: 02-09-2009, 07:51 PM
