Thread: Glow plug light flashing and cruise control not working 2.0 tdi 170
Results 1 to 10 of 16
  1. Glow plug light flashing and cruise control not working 2.0 tdi 170
    Oct 2009
    Chelmsford UK
    Hi
    I have a 2007 A3 2.0 tdi 170 on 95k miles, which, since the injector recall and cam belt change has become a little rough at idle and smells quite strongly of unburnt desiel/oil on occasion. The possible causes of these issues are not my primary concern (though suggestions would be welcome), but I am adding in this detail just in case it may be related to my main problem.
    Three times during the last couple of weeks the glow plug warning light a has suddenly started flashing together with a noticeable restriction of power; rebooting the car (turning the ignition off and on again) resets the light and all is back to normal. A non-Audi specific fault code reader at the local garage shows no faults logged. Each time the issue has arisen at something approaching motorway speeds (60 -70ish) and there has been some minor, but perceptible misfiring at some point in the journey; maybe half a second of hesitation etc.
    Now I know there are a lot of things that can cause this and my initial thought is a failing egr valve (which I will be taking a look at at the weekend), but on the last occasion I notice that the problem also took out the cruise control system and the ignition on/off trick only fixed the warning light and took the car out of limp mode, but did not solve the cruise problem - this resolved itself the next day.
    I cannot be sure that the glow plug flashing was accompanied by the cruise control fault during the first two failures.
    Does the link between the warning light/limp mode/cruise failure help to suggest a likely cause for my problem, or can anyone suggest any tests I can do to help isolate the fault, please?
    On a separate note, I have always been of the understanding that this model is fitted with a DPF, but with all this recent activity I have taken to looking carefully at the available dashboard warning lights and I can see no evidence of one for a DPF. On this model and this year is it possible that one is not fitted?
    Thank you in advance for any answers/suggestions.
  2. Re: Glow plug light flashing and cruise control not working 2.0 tdi 170
    Jan 2012
    Coding Something
    170's were all fitted with dpf's on the 8P, even the new 140's seem to have them, the older 140's didn't.
    I would be looking at this as a 1st point of check & checking soot levels to see what percentage its at, could also be a faulty sensor, but it requires vcds or the like to look at things properly, so either find someone local to scan & help diagnose, got a garage or buy vcds yourself as there's only so much a handheld reader can do tbh.
  3. Re: Glow plug light flashing and cruise control not working 2.0 tdi 170
    Oct 2009
    Chelmsford UK
    Quote Originally Posted by NHN View Post
    Thank you for this clarification. As I don't have a DPF warning light, does that mean that the flashing glow plug warning is the subsditute indicator? What do you mean by check the soot levels; remove the DPF and do a physical inspection?
  4. Re: Glow plug light flashing and cruise control not working 2.0 tdi 170
    Jan 2012
    Coding Something
    You need to get it diagnostically checked with vcds to ascertain what readings it is showing for the dpf sensor, this will also allow you to force a regen.
  5. Re: Glow plug light flashing and cruise control not working 2.0 tdi 170
    Oct 2009
    Chelmsford UK
    Thanks for this. I'd just googled how to check the soot level and learned that what you meant was to check with vcds.
    I am getting more certain that this car has no DPF though, as it has never done anything that seems like a regen and I have just checked the service book and found a section which should be ticked if the car is fitted with a DPF and it's blank. If this is the case, would you have any thoughts as to what the next most likely cause may be?
    Can the DPF be seen easily without removing the undertray?
    I realise that I should get faults properly scanned, but if there are any obvious checks I can do I would like to do these first?
    As the warning light has now reset, the cruise control is back and the car is currently running ok, will the fault code still be detectable?
    I appreciate your help, thank you.
  6. Re: Glow plug light flashing and cruise control not working 2.0 tdi 170
    Jan 2012
    Coding Something
    Every single 8P 170 I have known has had a dpf fitted, if yours hasn't then its an anomaly tbh.
    Just find someone local on the vcds map to login to the car for you, you cant do much else anyway, as to diagnose the issue you need to see whats faulting & it may have logged the fault already.
  1. B6 passat tdi glow plug light flashing
    By ctm73 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-06-2014, 09:36 PM
  2. Golfgt tdi 170 glow plug light +Dpf light please help!!
    By veedub76 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-01-2013, 10:07 AM
  3. Question Cruise control failure and Glow plug warning light flash
    By vw_craig in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-12-2012, 08:13 PM
  4. VW Caravelle cruise control not working flashing glow plug light
    By mundella in forum Touran - Sharan - Caravelle
    Last Post: 17-04-2009, 10:38 AM
