Thread: A8 steering wheel in a4?
  1. A8 steering wheel in a4?
    May 2013
    England
    Looking at upgrading my current 3 spoke wheel to one with radio controls and paddles. Have been offered one from an audi a8 but not sure if it will fit? Part number is 4f0124a. 4f0419091aq.
    If so I take its a DIY job to fit then find someone who can program in?
    thanks in advance
  2. Re: A8 steering wheel in a4?
    Jan 2012
    Coding Something
    It may fit, but airbag is the issue, there are 2 types, so you need to remove your airbag, no need to disconnect just unbolt from rear, lift airbag forward & take images of rear of bag or the wheel insides, then post up pics of the A8 wheel & yours so we can ascertain which airbag type you have, also the A8 loom may need modifying to work on your car, can be done but IMHO look for an mfsw version of your wheel.
    Also have to make sure you have the correct slip ring & steering module, along with vcds & spline socket.
    We can offer this service with a supply/fit solution if interested, whereabouts are you located?
  3. Re: A8 steering wheel in a4?
    May 2013
    England
    Thanks for your help I'm based in bristol, what do you mean by 4 spoke the wheel looks identical to my wheel so will my air bag not fit? Thanks again
  4. Re: A8 steering wheel in a4?
    Jan 2012
    Coding Something
    Sorry I was reading another thread on another forum & posted wrong info, someone else was asking me about airbags & wheel swaps lol.
    I've edited my post with new info.
  5. Re: A8 steering wheel in a4?
    May 2013
    England
    Would you be able to tell from a picture of e a8 wheel with air bag removed my wheel is a standard one with no buttons is identical shape to a8 one
    also if it helps the a8 is a2006 my a4 is a 2005
    quick update wheel purchased checked and both looked same inside so went for it, what sort of price is the modular likely to set me back?
  6. Re: A8 steering wheel in a4?
    May 2013
    England
    UPDATE got around to removing my air bag at long last after finaly having some time to try fit this, i have got pictures of both wheels, first being the one on the car and second being the wheel i bought, to me they look pretty much identical but just wanted to make sure, part numbers for both are - Current one fitted 8po 419 091 bj tna and the one i bought is 4fo 419 091 aq 1kt. Also what else do i need to purchase. Thanks again for any help
  7. Re: A8 steering wheel in a4?
    May 2013
    England
    Wheel has been conformed as the correct one now I'm looking for the slip ring and came across this one on eBay. It has the cruise control already which is what I want to do at the same time, my only question is my rh stalk has control for the dis ect is it possible to swap this over onto it? Link is AUDI A6 C6 05-10 INDICATOR WIPER STALKS 4F0 953 549 A 4E0 953 541 A 4E0 953 521 | eBay
  1. Wheel Wobble with small turns of steering wheel
    By balmer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-03-2010, 07:36 PM
  2. Steering wheel lock on an GT MFD wheel?
    By rgarner in forum Golf MK6 - 2009 - 2013
    Last Post: 10-08-2009, 09:49 PM
  3. Question steering wheel boss for mountey wheel
    By Shaunbing in forum Golf MK3 - 1993 - 1999
    Last Post: 21-05-2009, 02:47 PM
  4. Mk5 Standard Multifuncion steering wheel to R32 wheel
    By Caudy in forum Golf MK5 - 2004 - 2009
    Last Post: 18-04-2008, 12:44 AM
  5. Can the steering column cowling be removed without removing the steering wheel?
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-04-2008, 06:48 PM
