Thread: Rear door window removal
  1. Unhappy Rear door window removal
    Nov 2010
    Can't remove the dowel on my rear door window. How hard should I hit it????? Should I be pushing it in or pulling it out????
  2. Re: Rear door window removal
    Quote Originally Posted by howard6212 View Post
    the dowel is in 2 parts, the inner peg is about 4mm dia and just pushes out towards the door skin, the outer will then come out easily, the inner may take some finding inside the door!
  3. Re: Rear door window removal
    Norfolk
    Screw a self tapping screw in the middle and pull the dowel out with molegrips/pliers.
  4. Re: Rear door window removal
    Oct 2005
    sligo ireland
    had same problem trying to get dowel of manual windows rear buy spare one off ebay
  5. Re: Rear door window removal
    Oct 2009
    Worthing
    They are only about 50p at the dealer. A small screw driver or two are your friends if you can't find a suitably sized screw. Putting them in is harder! Don't drop it on refitting.
  6. Re: Rear door window removal
    Sep 2008
    Reviving this one because I've just had to take a back door apart.
    The dowels in question are both of the split type, and I found I could fit a pair of fine/needle nosed pliers directly on them and out they came.
    A bit of wd40 probably helped. Doing it this way also means you can stick a drill bit or thin screwdriver through the dowels to reduce the risk of dropping them.
    I was expecting a right battle after watching a bloke on YouTube struggle with the screw/bolt method. Think he was using a screw that expanded them too much.
    When reinstalling, make sure the glass is seated correctly on the carrier, not behind it, and that the holes are lined up exactly.
    As mentioned before, a spare set of dowels is a good idea
  7. Re: Rear door window removal
    Nov 2014
    Oxford
    Just did mine last week as had the doors stuck shut due to a faulty lock mechanism!!
    I took a flat head srew driver roughly the same size as the inner dowel and pushed it through. Did not need a lot of force. When putting it back together put the 2 pcs in, centralized them and simply slid the window on top of where they go and gave the window a gentle push and it snapped in place.
  1. How To Removal of door/window trim
    By rosco in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-02-2013, 12:54 PM
  2. Question a3 tdi quattro 5 door window switch removal
    By fosters8939 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-01-2013, 11:14 AM
  3. 2003 avant rear quater window removal
    By avantben in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-07-2011, 09:16 PM
  4. Question Cabriolet rear window removal.
    By bertwelsh in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 24-05-2010, 09:43 PM
  5. Rear window removal...
    By screech in forum Golf MK4 - 1999 - 2004
    Last Post: 20-04-2009, 11:09 PM
