Thread: Convertible instrument panel removal
Results 1 to 9 of 9
  1. Convertible instrument panel removal
    Apr 2010
    South England
    I am hoping it just a light bulb thats blown, but the instrument panel has a dark patch in the perfect location...I was using the car last night and couldn't see how fast I was going between 0 and 50mph!
    I've had the unit out of my old Mondeo by trial and error before, but I don't want to run the risk of breaking anything on this car. Does anyone know how to remove the instrument cluster from the dashboard?
    (N) 2.6 V6 Audi Convertible Europa Blue
    (14) E350 AMG Sport Estate Obsidian Black
    Gone: (59) 2.0T A4 S-Line Avant (B8) Lava Grey
    (02) 1.8T A4 sport saloon (B6) Denim Blue
  2. Re: Convertible instrument panel removal
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Remove the screw/screws which hold together the steering column shroud/cover and remove, this will expose 2 screws at the bottom of the binnacle/cluster unit.
    Pop out these 2 screws and wiggle the unit out of the dash, job done.
    You may need to remove the steering wheel in order to remove the first shroud/cover but I cant remember if there is a special way to do this in the event of the car having an airbag fitted.
    If the steering wheel is off there will be two screws fitted vertically from below that hold the two shroud halves together.
    There is then another screw in the lower half ( central) that goes upward from 5-o-clock toward 11-o-clock diagonally which holds the top half to the steering column via a circular clamp.
    With this lot undone and removed your cluster comes straight out very easily, PAY ATTENTION TO A COUPLE OF OTHER SCREWS LURKING THAT I MAY HAVE MISSED
    Stuart
    2 0 0
  3. Re: Convertible instrument panel removal
    Apr 2010
    South England
    Perfect thanks
  4. Re: Convertible instrument panel removal
    Apr 2010
    South England
    Nuts, it's not the bulb. The problems only just occurred, so I'm wondering what it could be.
    I might buy another bulb just in case the other is defective.
  5. Re: Convertible instrument panel removal
    Oct 2009
    10 Post(s)
    Before you buy anything just try a known good bulb from elsewhere in the cluster
  6. Re: Convertible instrument panel removal
    Apr 2010
    South England
    Quote Originally Posted by fourringsrus View Post
    Funnily enough, I was thinking about that the other day. Thanks
  7. Re: Convertible instrument panel removal
    Apr 2010
    South England
    Hmm it's not the bulb
  8. Re: Convertible instrument panel removal
    Gwent
    My guess is a crack in the printed circuit board. It should be possible to strip the instruments down, find the crack. If you can identify which track needs repairing, solder a 'jumper' in to bridge the crack. If you don't like tinkering best get a s/hand spare?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  9. Re: Convertible instrument panel removal
    Apr 2010
    South England
    I'll have to find some time, otherwise it's a trip to the garage. It was ok during the summer but now the dark nights are drawing in, it's more noticeable.
  1. instrument panel removal
    By old rocker in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-07-2010, 09:37 PM
  2. Instrument Panel
    By j4s0n88 in forum Chat - Anything with wheels
    Last Post: 18-09-2008, 07:06 PM
  3. Instrument Panel
    By SIMONGTTDI in forum Golf MK4 - 1999 - 2004
    Last Post: 23-11-2007, 09:59 PM
  4. Instrument Panel
    By alex_mcc in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-08-2007, 09:42 AM
  5. instrument panel
    By shazzies in forum TT - 8N Forum - 1998 - 2006
    Last Post: 01-03-2007, 01:22 PM
