Thread: Passenger side mirror indicator
  1. Passenger side mirror indicator
    Aug 2010
    Birmingham, UK
    Hi all
    can anyone kindly confirm the mirror side indicator as having part number 5K0 949 101 for a mk6 golf with puddle light and folding mirrors
    can't seem to find much info
    cheers
    2009 MK6 Golf - 2.0 GT TDI, lux pack, CW, Bluetooth HIGH, reversing camera and RNS 510 retrofits
  2. Re: Passenger side mirror indicator
    Aug 2010
    Birmingham, UK
    For anyone who comes across this, part for mirror indicator with puddle and folding is 5k0949101a
    Sent from my Nexus 4 using Tapatalk 4 Beta
  3. Re: Passenger side mirror indicator
    Scunthorpe
    How hard is it to replace the bulb? Is it one bulb for the indicator AND the puddle light?
  4. Re: Passenger side mirror indicator
    Aug 2010
    Birmingham, UK
    for the puddle light its a seperate W5W 'wedge' type bulb - identical to the sidelight type bulb in the headlights - this can be replaced on its own
    the indicator 'bulb' on the other hand is the ENTIRE housing - i.e. its the clear plastic lens complete with the lower black part of the mirror casing including the puddle light casing - total cost from the parts counter - £40 (they kindly rounded it down for me)
    it isnt that difficult with some patience. all you need is a T10 torx screwdriver
    step 1) remove the mirror glass (tilt all the way down and to the left and then get a finger or something behind the outside edge and pull towards you gently and smoothly - will pop off, remove the positive/negative terminals for the heater element - place the mirror glass somewhere safe
    step 2) remove the 3 T10 torx screws holding on the mirror adjuster motor (big round black thing) - DO NOT REMOVE THE SILVER SCREW IN THE MIDDLE - remove the plug for the motor and place to one side
    step 3) remove the two screws holding the black outer trim in place - along the top edge will be two 'pop' clips which are securing the mirror 'cap' (colour coded part) to the black trim - pop this off - place aside
    step 4) remove the 2 tabs holding the mirror cap in place - place this aside also
    step 5) the lower black housing should now be left attached to the actual metal mirrror with one tab at the front and a pin at the rear - release the tab at the front freeing it from the mirror housing and the bottom should be free for you to release the puddle light bulb and the power plug for the indicator.
    step 6) to put back together - reverse from step 5-1
    not that difficult at all just needs some patience! i finally have a working indicator!
  1. Passenger side wing mirror
    By garyhamilton200 in forum Vehicular windows, Glazing and Tinting
    Last Post: 09-04-2012, 08:40 AM
  2. Help! Changing Passenger Side Mirror
    By hana17 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-02-2011, 05:39 PM
  3. Passenger side wing mirror fitting
    By m8gic in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-12-2010, 12:09 PM
  4. Passenger side mirror
    By Simon Hibbert in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-02-2008, 10:04 PM
  5. Passenger side mirror adjusting itself
    By ryan408 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-12-2007, 08:39 PM
