Thread: Removing the cover of the front ashtray.
Results 1 to 10 of 11
  1. Removing the cover of the front ashtray.
    New Forest
    80 Post(s)
    I've looked at a few threads about this, on this forum and others and the suggestions appear to be, lever up the ashtray cover, after removing the two bolts but all that applying a bit of brute force seems to do, is bend the plastic attached to the lid.
    Anybody actually done this particular exercise and care to advise as to how I should do this?
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  2. Re: Removing the cover of the front ashtray.
    Sep 2011
    Lurking over a keyboard ...
    In SG all it states after removing the screws is to use a flat blade screwdriver where the red line is in below image to lever up the ashtray ... then from what I can tell the ashtray frame/cover is out as a unit ...
    2 0 0
  3. Re: Removing the cover of the front ashtray.
    New Forest
    80 Post(s)
    I can do that bit - thank you for pointing it out - just cant get the actual cover off, or, get the whole assembly out.
  4. Re: Removing the cover of the front ashtray.
    Sep 2011
    You may need to remove the AC control unit as the SG steps go like this ...
    i) Remove AC control unit
    ii) Remove trim below the AC control unit
    iii) Open ashtray remove insert
    iv) Remove housing/frame for ashtray
    vi) Then it show ashtray frame & cover as a unit out from console and shows how to unclip ashtray cover
  5. Re: Removing the cover of the front ashtray.
    Sep 2011
    Check your inbox ...
    2 0 0
  6. Re: Removing the cover of the front ashtray.
    46 Post(s)
    Does this help any?
    Sorry for the mumbled swearing
    3 1 0
  7. Re: Removing the cover of the front ashtray.
    Jan 2011
    Stafford, UK
    Does this help any?
    Thanks for that Chris, I have downloaded it to my PC for reference.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  8. Re: Removing the cover of the front ashtray.
    Sep 2011
    Quote Originally Posted by ragebe View Post
    I was viewing the area today ... you have also seen the exploded views now ... IMO without removal of the trim below AC controls you will not be able to remove the whole ashtray system from the console ...
    2 0 0
  9. Re: Removing the cover of the front ashtray.
    New Forest
    80 Post(s)
    Quote Originally Posted by gupsterg View Post
    Spot on. I've followed your instructions, removed £2.20 in silver, one receipt from a car-park, one Costa Coffee card (requires stamping at Shell Fuel Stations) and one timetable, for the Hythe-Southampton Ferry. I now have a plastic box, wedged twixt ash-tray cover and console trim, trying to bend the plastic for the ash-tray lid back into shape.
  10. Re: Removing the cover of the front ashtray.
    Apr 2013
    Cambridge, UK
    I also have stuff that has fallen through behind the ash tray cover so looking at how to remove it. However, It appears there trim above the ash tray is getting in the way. Do I need to remove the AC unit to do this ? If so could you please provide instructions ?
  1. Front ashtray issue!!
    By nilocp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-11-2012, 06:32 PM
  2. Question Front ashtray
    By Macdoon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-03-2011, 10:23 PM
  3. How To Remove B7 Front Ashtray cover (aluminium, not wood)
    By skilaufen83 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-08-2010, 10:45 PM
  4. Question Remove Front Ashtray
    By mtnbk7 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-07-2008, 01:02 AM
  5. How To Remove Front Ashtray Cover
    By gunshotx in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-02-2008, 09:54 AM
