Thread: Brake light fuse location
  1. Brake light fuse location
    Oct 2010
    Suffolk, UK
    Just had the left brake light warning go off, visually verified courtesy of the reflection in the bus behind me. Went to replace the bulb and that didn't cure it (old bulb had intact filament but I swapped it anyway).
    I've had a quick look in the manual and it doesn't list a fuse for the brake lights; can someone point me in the right direction please?
    2013 Mk7 Golf GT 2.0tdi DSG
    2005 A3 Sportback 2.0tdi Sport DSG
    Previous:
    2006 A6 Avant 3.0tdi Quattro Le Mans
    2004 A4 Avant 3.0 (petrol) Quattro Sport
  2. Re: Brake light fuse location
    Apr 2007
    France
    UVB, according to my wiring diagram, there is no separate fuse for brake lights. There is one fuse for lighting circuits (10amp) be certainly not for individual rear lamps. Suggest you look carefully at the left brake lamp holder and associated wiring/connectors for corrosion and/or bent pins etc. Good luck.
  3. Re: Brake light fuse location
    Oct 2010
    Suffolk, UK
    Thanks for the pointer. I managed to narrow it down to me confusing the brake light with the fog light in the tailgate!
    Previous:
  1. Front side light fuse location
    By nickkk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-08-2018, 12:09 PM
  2. Please Help Courtesy light in avant boot fuse location number?
    By leighton1271 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-11-2010, 02:18 PM
  3. Tail light fuse location?
    By James H in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-02-2010, 11:08 PM
  4. Brake Light/ Fuse
    By rpe2 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-04-2009, 06:31 PM
  5. Brake light fuse
    By neilsgotaskoda in forum Golf MK4 - 1999 - 2004
    Last Post: 19-11-2008, 11:32 AM
