Thread: Budget tyres urgent advice needed
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
  1. Budget tyres urgent advice needed
    Nov 2012
    North Somerset
    Folks
    I'm going to France on Saturday evening and want to change my tyres I'm still on winter tyres. Due to cost and being skint. I'm looking at budget tyres I'll be fitting 225/55/16W due to the fact that they are spec'd by Audi and they are cheaper and more readily available than the 205/60's
    A local place does Mazzini tyres (never heard of them) £270 fitted for 4
    Anyone heard of Mazzini ?? also can folks recommend some budget tyes makes they've used cheers
    A6 C6 Avant TDI, de-Badged, LED side lights, LED numberplate lights not just bulbs! so far!!
  2. Re: Budget tyres urgent advice needed
    46 Post(s)
    I'd be more pushed towards mid-range/premium part worns to be honest if I were in your situation!
    Audi tried selling me Himmer 2 Effiplus back in January for £70 a corner (255/35/19) and I swiftly declined their offer.
    Have a look thru this https://www.vwaudiforum.co.uk/forum/s...Premium+budget
  3. Re: Budget tyres urgent advice needed
    Mar 2008
    High Wycombe
    If money's that tight, I'd be inclined to go for a decent brand part worn rather than a Ditchfinder 5000.
    I know the usual worries about part worns - you don't know the history, why was the tyre removed from the previous car etc, but if you can inspect the tyres before you have them fitted, check inside and out for any bulges, cracks, splits or perishing, check the manufacture date, then they should be fine - certainly no worse than buying a used car with 4 tyres.
    Or, just keep the winter tyres on for the trip - they'll probably still perform better than el cheapo budget tyres.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  4. Re: Budget tyres urgent advice needed
    Nov 2012
    North Somerset
    Thanks for the replies guys (I'm a poet and didn't even know it) and the suggestions. I think I'll leave the winters on for now there's not much time to shop around. The best used branded seem to be on ebay, problem there is you can't really inspect them as much as I'd like to. I've been doing a search locally and there doesn't seem to be many part worn dealers near me, those I've called say the tyres size I'm after isn't that common, unlike 205/55 for instance.
    Like Sir Alan my search continues
  5. Re: Budget tyres urgent advice needed
    Feb 2009
    Glasgow UK
    Hey Cha6dders mate.........I think we're all skint at the moment, so feel your pain....lol
    As far as the tyres go, have you considered the Barum Bravuris 2???
    Myself and quite a few others have switched to these recently, on 19's a set of Conti's / Bridgestones or similar run around £1200 while the Barums are around £600 or less.
    I've had mine on now for around 3 months or so, front and rear with no issues, in rain / dry / snow etc and they've handled really well.
    They're made by Continental in Czech Republic, so a good brand behind them too
    Looking at £343 for all 4 which I know is a little more, but I'd personally recomend against buying the ditchfinder brands out there, for your safety and your family's mate.
    Worst case scenario, a good set of quality part worns after thoroughly checking them could be the answer.
    Four (4x) Barum BRAVURIS 2 101W XL 225/55/17 R17 Set of Tyres | eBay
    I know its a little bit more again than perhaps what you want to pay, but might be worth considering?
    They are through National Tyres which no doubt has a branch fairly near to you and could be fitted as soon as you like I'm sure
    Hope you get sorted Cha6dders
  6. Re: Budget tyres urgent advice needed
    Mar 2008
    High Wycombe
    Just had a look, Blackcircles will do a set of Kumho tyres for you (ChA6dders) for £390.80
    Yes, it's £120 more than the Mazzinis, but I've always been happy with Kumho in the wet or dry.
    They'll also do credit on them, so you could have the set for £33 per month over 12 months.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  7. Re: Budget tyres urgent advice needed
    Sep 2011
    Lurking over a keyboard ...
    Hi Chadders ,
    As you know mate my car had 4 different manufacturer tyres@purchase all had 6-7mm, kept the 2 best (goodyear/hankook) then got part worns of same brand/depth and paired on axles ... cost = less £80 for change over & rubber, done so far 14K on them ...
    I would not fit el cheapo vs part worn branded tyres and as NickPicks says as long as inspected inside/outside and newish DOT marking all should be good ...
    ATB
    G
  8. Re: Budget tyres urgent advice needed
    Nov 2012
    North Somerset
    So seems the best to go for are good quality part worns I'll do some looking then as said in prev post it's just a matter of finding them.
  9. Re: Budget tyres urgent advice needed
    Sep 2011
    Mine were from ebay tyre shops ... looked for ones with 0 repairs ...
  10. Re: Budget tyres urgent advice needed
    46 Post(s)
    Quote Originally Posted by gupsterg View Post
    x2 - My winter tyres for the A3 I bought on eBay from a well known dealer. 6.5mm all round, Conti Winter Sport 3D all for £235 including rims!
    Winter Rims/Tyres - Did I get a good deal?
  1. Urgent advice needed on wheels - A3
    By sum-vwaudi in forum Wheels and Tyres
    Last Post: 10-09-2011, 05:28 PM
  2. Extremely urgent advice needed.
    By clarkyWRX in forum Golf MK3 - 1993 - 1999
    Last Post: 19-10-2010, 09:55 PM
  3. Urgent advice needed - A6 2.5 TDI
    By BobA6Avant in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-06-2008, 11:08 AM
  4. Urgent Advice Needed
    By Alun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-12-2007, 07:37 PM
  5. urgent advice needed
    By ANDYA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-07-2007, 09:55 PM
