Thread: MMI 2g High - Odd Sat Nav Map "fault" - losing road display but navigation ok
  1. MMI 2g High - Odd Sat Nav Map "fault" - losing road display but navigation ok
    Apr 2012
    Aylesbury, Bucks
    An oddity. Was driving home from London City to Aylesbury, used the sat nav cos it gives ETA and re-routes if traffic bad. Tooling up the M11 about half an hour into the journey, looked at the display and noticed it was all there - position arrow, compass, distance to go, and "zoom" range etc. BUT no road detail. The DIS was all present and correct as were the voice commands. So, everything ok except the actula map. Twiddled the "zoom" know, and when I got out to 2 miles the detail came back. Hmm thought I. A little further into the journey I had to zoon out to 8 miles to get map details. very odd thought I. After I got home, turned off, turned on, still no map detail. Left it off for half an hout - hey presto, back again.
    I'm guessing it's a DVD fault/glitch (original 2006 version), as everyhting else was fine and the actual navigation was still working perfectly.
    Guess I'll upgrade to the most recent DVD and hope for the best!
    2018 (2017MY) S3 2.0TFSI Sportback Quattro S-Tronic in Nano Grey Metallic.
    Black Edition, Reversing camera, Parking System Plus, Hill Hold, Super Sports seats, heated, Dipping exterior mirrors, B&O, Advanced Key, Magnetic Ride, Red Calipers, 19x8J 5-V-Spoke wheels in matte titanium.
  2. Re: MMI 2g High - Odd Sat Nav Map "fault" - losing road display but navigation ok
    Sep 2010
    Bristol, UK
    I have something similar......
    Almost everytime I drive to within a few miles of Taunton either North or South my Nav system says check DVD and I have no map, nor do I have any data on the DIS other than the arrow, but the driving instructions still work.
    A few miles later the Nav comes back to life and the data re-appears on the DIS.
    On scanning with VCDS I get
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H47 1060
    Revision: 00000000 Serial number: 364EL067564210
    Shop #: WSC 00623 210 88438
    VCID: 3B7F46487A7EBF6
    1 Fault Found:
    02261 - Data Medium
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 7
    Fault Frequency: 12
    Reset counter: 163
    Mileage: 191057 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 22:00:17
    Freeze Frame:
    Hex Value: 0x5188
    Hex Value: 0x16D6
    Hex Value: 0x0410
    Hex Value: 0xF961
    So I believe it is a dead bit of the DVD, I have had it somewhere else when driving but can't remember where!
    I do use a backup copy of my genuine Nav DVD as I've had bitter experience of very expensive media failing! So to fix I think I need to make a new copy!
    Cheers,
    AndyB
    Current: 2009 Q7 S-line 240 PS 3.0l TDi
    Gone but not forgotten: 2006 '06 Audi S6 5.2 V10 Quattro
    1 1 0
  3. Re: MMI 2g High - Odd Sat Nav Map "fault" - losing road display but navigation ok
    46 Post(s)
    The medium is your disc. Check it for scrapes etc and consider getting a new one.
    A DVD lens cleaner wouldn't do any harm either.
  4. Re: MMI 2g High - Odd Sat Nav Map "fault" - losing road display but navigation ok
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by ukandyb View Post
    x2 , Great post/info ...
  5. Re: MMI 2g High - Odd Sat Nav Map "fault" - losing road display but navigation ok
    Apr 2012
    Aylesbury, Bucks
    Thanks Andy - although mine is somewhat different in that the display was still there - but only at smaller magnification - and it stayed off all the way home (except for an 8mile view as I mentioned) but today is back to normal. I've used it to/from work and will continue to do so to see if it's stable. I'll also give the DVD a polish :-) but ultimately a new one was on my list anyway!
  6. Re: MMI 2g High - Odd Sat Nav Map "fault" - losing road display but navigation ok
    Sep 2010
    Bristol, UK
    The grey matter cells are remembering something..........
    You might want to run an optical scan with VCDS to check all is okay with the MOST fibre optic ring. I can remember my Sat Nav playing up before the Bluetooth module died
    AndyB
  7. Re: MMI 2g High - Odd Sat Nav Map "fault" - losing road display but navigation ok
    Apr 2012
    Aylesbury, Bucks
    I don't think it's that - I'd have lost all information if the MOST ring was down. I did still have the map info available - juts not at the closer scales. Could be media, could be the read head in the DVD. Time will tell (and a scan if I get one done :-) )
  1. Replies: 4
    Last Post: 08-10-2015, 02:54 AM
  2. Display radius on MMI 2G Sat Nav
    By six_or_out in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-03-2013, 11:40 AM
  3. Golf MK7 - Anyone "SEEN" the standard SAT NAV yet !!
    By JDB007 in forum Golf MK7 - 2013 - 2019
    Last Post: 22-12-2012, 11:28 AM
  4. Question A8 Sat Nav "reload DVD"
    By Gerbil in forum In Car Entertainment
    Last Post: 02-01-2009, 04:42 PM
  5. "CD-ROM read error" - Audi A4 Sat Nav Plus
    By teesah in forum In Car Entertainment
    Last Post: 11-08-2008, 11:21 PM
