Thread: Clunking noise when starting engine
  1. Clunking noise when starting engine
    Oct 2012
    Canvey island
    Hi can anyone help I have a 2007 2.0 TDI when first starting all is ok but if I turn the engine off and try and start within 15 minutes there is a loud clunking noise from the engine and it don't start it takes 2 to 3 try's to start the car and it runs with no problem.
    can anyone help it turns heads when it happens not in a good way
    thank you in advance for any help
  2. Re: Clunking noise when starting engine
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Any vibrations felt at Idle? Possibly DMF knocking. Bad starting maybe a weak signal from Crank Sensor due to Flywheel if it has excess play. If you can check for any fault codes that may be stored it would aid the diagnosis.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Clunking noise when starting engine
    Oct 2012
    Canvey island
    Hi thanks for the reply it is ok when it is at idle just clunking on starting have not got equipment to see if any fault code is there will have to take it to audi to plug it in and see
  4. Re: Clunking noise when starting engine
    Oct 2012
    Canvey island
    checked for any fault codes none was shown but not between 1000 and 2000 RPM there is a knocking/rattle comming from the engine bay somwhere over that all is ok took it to my local garage and they said the engine mounts had gone got them replaced 500 pound later still dose the same and ideas?
  5. Re: Clunking noise when starting engine
    Nov 2008
    20 Post(s)
    Thats because it has a very good chance to be the DMF, as mentioned.
    Alan.
  6. Re: Clunking noise when starting engine
    Jan 2014
    India
    Check the starter mounting bolts for tightness. This is the most common reason for clunking/grinding noise...
  1. Please Help clunking noise on a4
    By iceman130577 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-07-2010, 09:16 PM
  2. Please Help Clunking noise
    By davey_g23 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-05-2010, 05:00 PM
  3. Clunking noise!
    By Godzilla in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-06-2009, 11:32 AM
  4. Clunking Noise
    By Gee_Hee in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-02-2009, 10:22 PM
  5. Clicking noise when starting engine?
    By revo_20vt in forum Audi A3 - Archive Topics
    Last Post: 29-01-2008, 01:26 PM
